Well, if you have a static offset you should check this part of circuit. Basically temperature shown on display is the sum of the temperature of the ntc + the temperature of the k-type probe. If you short the k-type connector with a single piece of wire, you should read the temperature of the ntc on display, this should be similar to temperature ambient (if meter is not manipulated too much).
Inviato dal mio Nexus 6P utilizzando Tapatalk
