I desoldered all solder jumpers (U26,U27,U29,U31), thus cutting out 12V,5V,3.3V from other components. The problem is still persisting, showing that the problem is indeed in power supply circuitry.
I've went through datasheet, and there is a principal diagram where the IC is connected exactly as in service manual of the home cinema.
I might look for other failed components
