I had a modern digital thermostat given to me, from a house that is said to have had the DTS appearing to lose power, so the screen would cut out and so was the 3kW baseboard heater. I'll find outmore on that later.
I opened the DTS, and right away saw what looked like a thumb-sized black ash/charred/blast area, centered over the corner of the ATMEGA169, and a row of little SMD caps. And on the power PCB, a few mm opposite that, there's a near thumb sized, coal black, blast mark, that was centered on a SMD 0.8A Thyristor/SCR
https://www.mouser.ca/datasheet/2/240/Littelfuse_Thyristor_EC103xx_SxSx_Datasheet.pdf-463960.pdf.It looked like a blast or big arc went from it, then under 2 big power resistors. on it's PCB, and covered the caps/MCU right arcoss from it, and the tops of stuff on the SRC PCB, looks clean, like 2 white mini fuses 1.5cm away, were still clean on top.
But the cap's on the other side, looked complemely toasted, until I cleaned them. And everything seems fine. IDK about the small SCR for sure, but it's not shorted, it's big pin side, sort of looks like it's solder was melted weird, like on Mosfets I've seen fried.
Or maybe it's just soot? Electrostatically sticking ? The tenents used to burn candle's/incsene's??. I've seen cigarette tar get on these same exact same model thermostats before. But this stuff, litterally was like coal dust, and higly localized like a blast/high speed cooking, I should have taken a snap.
So I've been reverse engineering the power PCB, for the upto 3kW, 240V heater. And I sort of get it, but it's not really working in LTspice. Too late to go trying it on the variac, but I think I have all the power PCB.
I measured the 100Hz inductance of the little transformer, and all but 1 of the zener's, but I still can't get the 100uF cap to charge at all, it's for the LV Vcc on the other PCB.
I don't get how the SCR is triggering the Triac correctly , and the triac has 0.7amps coming from it's gate, so is that even possible ? The BJT network is over my head to calulate at AC, but I have that doing something useful looking for the gate triggering, and/or sensing for the MCU to control the SCR... I just assume have a better working model before I try powering it on the variac.
Honeywell thermostat.asc (7.29 kB - downloaded 59 times.)
