2uF 630VDC, but they must be rated for pulse application. You probably will be best to get a 4uF 400VAC motor run capacitor with push on terminals, and use 2 short thick ( 1.5mm) wires to connect them to the board. That way when it next fails ( after a year or two) you just plug in a new 4uF capacitor.
