Thanks for the replies.
I havent had much time to work on it but I got something that might help!
I read that in stick mode the machine switches polarity, so I tried stick and it gives me a "HELP 21" error when I try to weld! It lets me select stick, but when I enable output (by pressing the torch button in lift-arc, or when I set output to ON), it gives me error 21.
The manual states: "Help 21 Display - Indicates voltage or current feedback has been detected with contactor off.". Which is confusing me because I don't get the error until I turn the 'contactor' ON? Or there's the problem: some part of the machine thinks its off when you turn it on?
Actually, its a bit unclear to me what they mean by 'contactor', most of the time its 100% clear that they mean the button/pedal to enable output, but there's also this line on lift-arc which has me a bit confused: "The solid-state output contactor does not energize until after electrode is touching workpiece.". What 'solid-state output contactor'? The IGBTs? Or they mean the torch button doesnt do anything untill you touch the workpiece, until the sensing circuitry senses loop closure between electrode and workpiece? So then gas should not start flowing when you press the button just holding the torch in the air? With my machine it does...
Actually(!), lift-arc didnt work like it should from the day I got the machine. You should touch workpiece > press button > lift > arc starts. Well my machine its like: touch > press button > short/stick/buzz. I'v been working around it by doing this: press button without touching workpiece, gas starts flowing > very quickly tap the surface > arc starts. If I tap longer than a few milliseconds it sticks. Sometimes it wouldnt work and I would have to tap and scratch up to a dozen times before it would arc. But touching the workpiece and then pulling the trigger instantly tries to weld my tungsten to the work.
Actually(!!)... I'v also had problems using HF start from the day I got it. Sometimes -actually pretty often- I would press the trigger and I would hear a single tick! sound, like an arc jumping, no HF arc between torch and work tho, and nothing, machine displayed HELP 1. I would turn the machine off and back on, the error was always gone, I would fiddle with the ground connection, and usually it would just continue to work. Note that I never had any HELP 1 error using lift-arc.
The manual states: "Help 1 Display - Indicates a malfunction in the primary power circuit caused by an overcurrent condition in the primary IGBT switching circuit. Some possible causes are: shorted output diode, shorted output IGBT, primary current transformer CT1 located on Power Interconnect board PC2, HD1, PM1, or Inverter Control board PC1"
I went back to the store some days after I bought it because it kept happening. Btw I bought it second hand (~500hours, about 14k arc starts iirc, how much or how little is that?). The arc starting wasnt strong enough they said? They adjusted some 'crystal gap'? They also mentioned the HF start was sensitive to the total resistance in the loop, so torch, torch cable, ground cable, ground connection, wiring and connectors inside the machine connecting to the HF coil. I did notice myself that it seemed to happen more when my ground connection was a bit meager. It's been better after that but still happened sometimes. I worked around it by using lift-arc more.
I don't really see what HF start has to do with "error 1: overcurrent in primary IGBT circuits". Unless that 'tick' sound I heard was actually an arc jumping inside the machine somewhere... You were saying something about internal arcing?
The guys from the shop spoke of that too...
Actually.. when my AC broke I was welding with HF start and.... OOOOH! I remember, it was also HELP 1! That's why I thought little of it and just turned my machine off and back on, like I had been doing many times, only this time it didnt work fine after I turned it back on :sadge:
Man... from day one there were some things obviously wrong and I just kinda thought nothing of it. I feel so stupid writing this out. I couldv get it fixed under warranty XD
Lot of info. So what's going on here?
I should mention that:
-I have yet to completely disassemble everything so I havent inspected every single nook and cranny yet
-conformal coating is actually in pretty good shape overall, havent found any flaking or yellowing or scorching anywhere
-I actually thought the machine was very clean, the lighting/shadows really make it look bad in the photo, still tho I guess I shouldnt underestimate the grime, I want to clean it for sure
-by wash and bake, you mean bake purely for drying purposes right? Or with some other purpose as well?
-still havent found any damaged components or signs of arcing
-I have yet to go through all of the technical manual's measurements
-I did measure some stuff on the IGBT snubber board, as per manual's instructions, I believe they have you measure some gate driver components, they all measured fine
-I actually energized the IGBTs' gates while measuring continuity through them with
, not exactly switching a load, but they all switched on and off fine
