hello , i have a sick puppy in form of 8 port gigabiy mannaged switch after firmware update failure
switch is pretty much ded without the brain , the only thing it does is power led
tplink only provides firmware patches, and probably not aplying them all in order was the problem, either way i do not have another v1 hardware switch of this type and can't pull the firmware out of it (all i have is v3, v4 , and some 5 port switches from v1 hardware but those might be different)
i pulled and saved content of the oryginal flash chip, tryed to flash it with what is on tplink site but file size is about 40% of the dumped rom
this thing is pretty old , tplink already at revision 6 with different cpu so they won't help
if anyone has working tplink tl-sg108e v1 and is willing to share the rom dump, i would be gratefull because i can't find anything by googling it
