Author Topic: TL866 II Plus Self-Check Error  (Read 2224 times)
Offline patolog1964Topic starter
  • Country: cz
« on: October 03, 2021, 09:45:19 am »
I have got a XGEcu Minipro TL866II Plus programmer with the latest software and firmware from XGecu website. It was working perfectly but couple of days ago, I started experiencing problems with the programmer. It showed messages of IC short circuit / over-current messages. When I did self-check from the test menu, I found an Error called "VCC ERROR:. I have attached the screenshot for the same. I need help to fix the issue.Can someone explain me how can i possibly repair this or am i scre*ed? :)
Should i check some pinout traces if its HW problem or is problem with SW? :)
Iˇve tried switching OS to 32 bit,no issue.¨
Thanks for any advice,would be grateful for any tips.
Iˇve uploaded screenshot of that error down below.
Offline drakepirate
  • Country: mo
Re: TL866 II Plus Self-Check Error
« Reply #1 on: March 08, 2023, 05:00:08 am »
Got similar Error on my TL866II+. :-BROKE
Let me know if you solved it Please...
Thanks.
Offline Yhoni
« Reply #2 on: April 03, 2023, 11:06:43 pm »
Hello friends, I have the same problem.
Anyone could fix it??
Could you share it, please?
Offline m k
« Reply #3 on: April 08, 2023, 02:19:50 pm »
Go back to earlier firmware and try USB port where it has never been.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
