Author Topic: Minipro TL866 II Plus Self-Check Error  (Read 6483 times)
Offline siddharth.lalwalaTopic starter
  • Country: in
« on: January 10, 2019, 06:09:13 am »
I have got a XGEcu Minipro TL866II Plus programmer with the latest software and firmware from XGecu website. It was working perfectly but couple of days ago, I started experiencing problems with the programmer. It showed messages of IC short circuit / over-current messages. When I did self-check from the test menu, I found an Error called "VCC ERROR:. I have attached the screenshot for the same. I need help to fix the issue. Can anyone let me know what part of the circuit board needs to be checked?
Offline Jonny
Re: Minipro TL866 II Plus Self-Check Error
« Reply #1 on: April 04, 2019, 04:49:31 am »
VCC refers to a voltage rail. It will be testing all possible voltage ranges that it can supply for programming. From the specs this unit creates "Programmable VCC from 1.8V to 6.5V, VPP from 1.8V to 18V chip"
I had a look in mine, directly behind the USB socket are 2 small inductors, these may be used to create voltages. Further back are 2 much larger inductors that are likely where you need to look. The related components are under these. Look carefully for physical damage, bad soldering etc. Mine has a SMD cap ripped off after it had been soldered on. Not the best quality control. Lucky for me it's not necessary.
You could probe the output of these switching supplies with a DMM or scope during the self test to see what voltage appears. I would expect a few steps in quick succession as it sets a level, measures it, then sets the next in order to test itself.
Good luck
Jonathan
OK OK  I'll probe mine so you know what you should get   :-/O    During test (USE A SCOPE, DMM won't show these pulses they're very short) and probing the ZIF socket
pins 1 to 5  show pulses in this order     8.5V  4V  2V  4V
       6                                                 8.5V  4V  2V  8.5V
      7 to 10                                         8.5V  4V  2V
     11 to 16                                        4V     2V
     17 to 20                                        2V
     21 to 29                                       4V      2V
     30 to 40                                      8.5V    4V   2V
Pulse widths are about 10ms with the 2V one being about 170ms in all cases. If not getting this you should trace your way back through the circuit from the zif socket and you should come to the source of the pulses and find out why they're missing or out of range. If they are all present and correct then the feedback lines must be bad and the micro can't see the values.
Jonny
Offline Dany
  • Country: sm
« Reply #2 on: May 06, 2020, 03:36:55 pm »
I have the same problem with the tl866ii plus programmer, the yellow led flashes after a firmware upgrade that has gone corrupt.
Were you able to solve the problem and if so can you tell me which procedure you used
Thanks
Dany
Offline coromonadalix
« Reply #3 on: May 06, 2020, 05:19:32 pm »
I had a problem in the past with corrupted firmware updates,  i was on win10 64bit,  somehow the updates where alway corrupted, even in admin mode,  tl866 inaccessible or bad device descriptor, yellow exclamation in device manager,    reflashed it in a win10 32bit and all went fine ... each new requested updates was done in a win10 32bit
« Last Edit: May 06, 2020, 05:21:17 pm by coromonadalix »
Offline drakepirate
  • Country: mo
« Reply #4 on: March 07, 2023, 02:02:16 pm »
I unsuccesfully tried to program  a 21V ST M2732b Eprom.
When I connected it back to USB the red led light flashed for a second it detects the programmer and inmediately after software says "No programmer found..."
I thought it was F1 (had no continuity but some resistance) so I repplaced it.
  Now programmer boots up but  it can't read any IC. Only some chips on determined Address (if I deactivate pin detect & ID check).
When I start the programmer and perform a system check.An error message appears. I checked all electrolitic capacitors and they seem to be fine.
1117 regulator seems to receive & convert right voltages 5/3.3V .
U4 ( second MC3306AD of target VDD Supply) output voltage is around 9V and Just noticed Q9 is quite hot, can't touch it for more than few seconds.
Is there Any other component or voltage to check? any of you  guys have experienced something similar? How to check overcurrent protection section?
Thanks in Advance
https://proghq.org/wiki/images/3/3c/TL866II_Schematic.pdf
https://proghq.org/wiki/index.php/TL866_II_PLUS
Drake
« Last Edit: March 07, 2023, 03:21:27 pm by drakepirate »
« Reply #5 on: March 07, 2023, 05:05:27 pm »
hum  tl866a or cs models  is not the software you show ??  it is minipro 6.85  the last one for the tl866 series,     xegcu 48 or 56  use other software ?
Sorry  its a v2 version
« Last Edit: March 08, 2023, 12:00:11 pm by coromonadalix »
The following users thanked this post: drakepirate
Offline drakepirate
  • Country: mo
« Reply #6 on: March 08, 2023, 03:28:29 am »
Software XgPro v12.50
« Last Edit: March 08, 2023, 03:42:58 am by drakepirate »
Offline rfancella
« Reply #7 on: March 09, 2023, 08:38:08 pm »
Drake,
I have almost the same exact issue only on pin 40.  Did you every figure out where to look or what was wrong with yours?
1734527-0
Thanks in Advance
Drake
Offline simyaci
  • Country: tr
« Reply #8 on: March 19, 2023, 01:56:47 pm »
I have that same problem ?
found a solution
Offline rfancella
« Reply #9 on: March 19, 2023, 02:23:55 pm »
You found a fix?
Offline drakepirate
  • Country: mo
« Reply #10 on: April 07, 2023, 02:59:52 am »
Tell us how you managed it. Please.
Offline simyaci
  • Country: tr
« Reply #11 on: November 12, 2023, 10:53:58 am »
problem win11
no problem other pc  win10
« Last Edit: November 15, 2023, 10:06:32 am by simyaci »
