Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
TL866 Won't Erase or Program W49F002U
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: TL866 Won't Erase or Program W49F002U (Read 563 times)
Quarlo Klobrigney
Frequent Contributor
Country:
This Space For Rent
on:
May 17, 2023, 04:17:00 am »
I'm trying to flash the BIOS of an old ECS computer because I need XP to work with some old software.
The computer booted up with an AMD 1400 just fine.
After I swapped the CPU for a 2000, it rebooted again just fine.
After accessing the BIOS to set the CPU multiplier clock, I got as far as entering the BIOS screen.
It then locked up. Yes the CPU is supported, and rebooting resulted in nothing.
Swapping the CPU back, the computer beeps, and results in no video on the monitor.
Resetting the BIOS did nothing.
Looking at the manual it will default to a PCI video card. Out with the AGP, in with the PCI card.
The monitor says wrong resolution for any PCI card I use.
Now to the bigger issue. The flash chip is a DIP 32 so direct plugin to the TL866 ver. 6.85.
The original file was 2 years older and I wanted to update it.
I read and saved the original first of course.
I have 2 BIOS ROM files, which I attempted to update and flash it, but the TL866 was having none of it.
I checked for a blank IC it said no.
No matter what I do the original file is still on the chip.
Does anybody have an idea why I can erase the IC but can't program it?
I don't see why, it's not OTP.
Here's a datasheet.
https://datasheetspdf.com/pdf-file/1233812/Winbond/W49F002U/1
Last Edit: May 17, 2023, 04:27:15 am by Quarlo Klobrigney
Logged
Voltage does not flow, nor does voltage go.
Quarlo Klobrigney
Country:
This Space For Rent
Re: TL866 Won't Erase or Program W49F002U
Reply #1 on:
May 17, 2023, 04:50:51 am »
It fails in the programming process at address 0x00D336.
I can repeatedly erase successfully and an empty check shows it's not empty at address 0x00C080.
Here are some photos.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
