Hi everyone!
This is my first post so thank you for welcoming me aboard.
I've had a TL866CS (upgraded to TL866A a while ago) for about 5 years. I'm running the Minipro app on Win XP (through Virtualbox, on a Linux or a Mac OS, same Win XP image). It has always been working so far.
I did not have the use of it for a year or so and, when I opened the app (v6.16), it read that the app was obsolete and needed to be updated. I did so, upgrading to v6.85... unfortunately. The app demanded i upgrade the firmware, which I did.
Then, when trying to read a PIC 12F675, I got the following message: "OverCurrent Protection actions! External short circuit / IC reverse or damaged!"
Of course, the IC is not reversed. And I've tried multiple new ICs. Reading, Erasing... every action gives the same result.
I read about issues with v 6.85 and corresponding firmware and found Radioman's firmware updater (thank you Radioman!).
I successfully performed the "reverse" firmware update to v 6.82 (firmware 3.2.85). The same error happened after the upgrade.
I also noticed, performing the "System self-check", that there was an error on the Ground Testing #16. I solved the issue with my soldering iron (probably a cold solder joint) and now everything is OK with the Self-check.
But I still get the same message... And I cannot program my PIC IC...
Any idea about what's going on here?...
Thank you in advance!
