if anyone ?
this would be very much appreciated.
it is for a 47" lcd tv.
thanks.
Search the part number on the board, it may tell you other tv models / sizes and do an google search ...
PLHC-T801A is the part number ?!?!?
google gives you people searching for it
also people that seems to have the schematic, but only give clues to fix it
Not the exact PSU as the schematic given appears to be for up to 42" models:
http://www.go-gddq.com/upload/2009_06/LC8-2A-LA.pdfPossibly close enough to at least help understand.
From personal experience with these psu's and from a first glance at the schematic beware of, (referring to schematic in link):
(bulging secondary capacitors of course...)
Bad solders on transformers
IC901 (ICE3AS02 standby power PWM)
C613,C625,C626 on main power
C310,C311,C315 on backlight power
thanks but this is not the right schematic.
the broken circuit is a fairchild FSQ510, there is none in this manual.
I replaced it (and a fried resistor) but the power is still ticking (one relay is ticking in fact)
the tick maybe a synonym of an short circuit still present, the supply tries to start and shutdown because of the short
