Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
[Solved] TL866II-Plus fails to program flash chip SST39SF020A-70
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: [Solved] TL866II-Plus fails to program flash chip SST39SF020A-70 (Read 1061 times)
jeraymond
Contributor
Country:
on:
February 23, 2022, 01:24:13 am »
I'm trying to program an SST39SF020A-70 flash chip with the TL886II-Plus but keep getting a "Programming ...Failed" error at 6.25%. Reading the chip and erasing works OK. I have a few of these chips and tried 3 and all show the same error.
I'm attempting to flash the 1.4 firmware for a E3632A onto it (
http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=HP_Agilent/Agilent_E3632A
I used the programmer a handful time successfully programming AT89S51 chips.
I've had no luck with an internet search on finding a fix. Any suggestions?
Last Edit: February 25, 2022, 06:54:55 pm by jeraymond
Logged
oPossum
Super Contributor
Country:
Very dangerous - may attack at any time
Re: TL866II-Plus fails to program flash chip SST39SF020A-70
Reply #1 on:
February 25, 2022, 03:39:07 am »
A14 may be open circuit or shorted to ground.
Logged
jeraymond
Contributor
Country:
Reply #2 on:
February 25, 2022, 06:54:25 pm »
Quote from: oPossum on February 25, 2022, 03:39:07 am
Thanks for the hint. A14 was shorted to A8 through some dodgy-ness on the PLCC32 to ZIF adapter. I was able to rework it and it fixed the programming problem.
What made you suspect A14 was the issue?
Logged
oPossum
fzabkar
Super Contributor
Country:
Re: [Solved] TL866II-Plus fails to program flash chip SST39SF020A-70
Reply #3 on:
February 25, 2022, 07:44:26 pm »
6.25% = 1/16th
That would suggest that the 4th uppermost address bit is stuck at 0.
Last Edit: February 25, 2022, 07:52:40 pm by fzabkar
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
