Author Topic: To definitely differentiate black zeners diode  (Read 600 times)
Offline abdulbadiiTopic starter
« on: January 23, 2023, 02:37:50 am »
How do we differentiate black zeners like below with that of a diode ?
Offline nostril
Re: To definitely differentiate black zeners diode
« Reply #1 on: January 23, 2023, 03:41:08 am »
There are a number of options, including:
1) checking the part number written on the component
2) checking its position in the context of the rest of the circuit
3) measure the component's zener/avalanche voltage
4) ask the person who designed the circuit  :P
Hope that helps
Offline Gyro
« Reply #2 on: January 23, 2023, 10:33:45 am »
I wish you would stop it with the lazy one line cryptic questions.
Best Regards, Chris
Offline jonpaul
« Reply #3 on: January 23, 2023, 11:00:23 am »
curve tracer
lab power supply and
VOM
j
Jean-Paul  the Internet Dinosaur
Offline Audiorepair
« Reply #4 on: January 23, 2023, 11:06:47 am »
Put your meter in diode mode.  Zeners nearly always measure in the 700mV range, standard diodes in the 500mV / 600mV range.
Other diodes like Shottky types can measure way lower.
You can do this with the diodes in circuit.
Try it, you will usually easily spot the zeners.
The following users thanked this post: abdulbadii
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #5 on: January 23, 2023, 02:54:48 pm »
some context to your question would help
