Hello !
I have bought a new multi charger tool: a ToolkitRC M7.
I have already a iMaxB6Mini (genuine), and a ISDT Q6 Nano from a friend to compare.
First warning: it is completly not calibrated out of the box !
I was having an error of about -0,18V ! So it will overcharge batteries
So with the hidden menu and my Keysight: I have done the calibration and now it is good
Second problem: big coilwhine but only when the Fan is active (starts spinning at >45°C ).
To check that: I have stopped it with a little toothpick and the noise is super audible
I have checked on the user manual: between 45-53°C the Fan is in slow mode (big coil whine), and >53°C Fan is in full speed mode and no coil whine.
So I have just teared it down and put my Siglent on the 2 pins of the 5V fan, here is what I have on picture 1:
An horrible PWM signal at 1kHz => that's why it is really annoying
Then, I have tried many capacitor value, and the best I have found is 47µF: the fan is faster and the coil whine is a less annoying.
==> I don't know is some of you have this charger, and have tried to fix the fan coil whine with another way ? It will be great to post your mods
Thank you
Edit: I have opened a ticket on ToolkitRC support, and have uploaded a video on Youtube here:
