Author Topic: Toroidal transformer hum  (Read 4801 times)
Offline Armadillo
Re: Toroidal transformer hum
« Reply #25 on: December 02, 2017, 04:04:25 pm »
Simply put some damping material in contact with the thing..
Any material that is non-magnetic and non-flammable/melt-able at normal temperatures.
 so that the energy is used up in it.
Also, how the toroid is mounted would make a difference.
Don't even waste your time listening to it.   >:D    :-DD
Offline adauphin
« Reply #26 on: January 06, 2018, 06:01:12 am »
I wanted to update this issue as I heard the hum again a few times over the last few weeks. Each time I opened the sub panel breaker and the hum stopped.
Tonight it hummed lightly again so I shut down one breaker at a time in the sub panel. Last time I did this I don't remember anything happening, but this time it was different.
When I opened the breaker for the microwave, the humming stopped, was dead silent. The microwave was not in use, only the clock and the two incandescent surface lights.
I closed the breaker again and the humming was still gone.
What can be in the microwave that could possibly allow DC into the mains after a period of time?
Anything else come to mind?
Offline Richard Head
« Reply #27 on: January 06, 2018, 06:22:11 pm »
Armadillo
Magnetising current is load independant.
But it is very much Volt.Second dependant.
Offline Armadillo
« Reply #28 on: January 06, 2018, 07:18:24 pm »
Armadillo
Are you responding to me?
Nevertheless, from what you say, then forget about transformer VA rating.
Just apply enough V for enough S ?????? Not in the real world.
Edit: Thanks for pointing out. In my previous response, i should use load current instead of Im.
« Last Edit: January 06, 2018, 08:20:58 pm by Armadillo »
