Here's the syslog I captured from it, I tried a few more times with different things plugged in and the other boards connected or disconnected, and it was substantially the same.
BCM76300010
Setting NAND Params
CFE starting from ROM
Chip specific init
TLB init
Board init
Starting memory configuration
Valid memory config = D3128256
Disable refresh - set byte lane 8
Setting up PLL
Setting up memory controller
Enable DDR encryption
SooooooooooooooR
Preparing to copy code to RAM
Prepare for NAND loading
Starting code in RAM
Booting Secured uCFE...
BCM97630 B0-BSEC uCfe v2.1.17 (CFE core v2.1, BSP_REV 17), Endian Mode: Little
Build Date: Fri Apr 9 17:48:43 EDT 2010 (kdasu@stb-mhtb-02)
Copyright (C) Broadcom Corporation.
DDR : Bank0:128MB@667MHz | Bank1:256MB@667MHz
NAND Boot : FlashSize 256MB on CS0, BlkSize 128KB, PgSize 2048B
NAND vendor timing : 98da9015 Toshiba TC58NVG1S3ETA00 SLC t1(33535233) t2(80000b98)
Secure boot : secure boot enabled, BSECK unlocked
Port lock : Enabled
--vvv----vv-----vv----------- ATV DUMP -----------vv-----vv----vvv--
cfg.espring_enabled size< 004 > u32< 1 >
bst[-1].version size< 041 > str< Signed PKG_DVD_3_1_013_02_BDX >
bst[-1].bootline_fmt size< 134 > str< boot -z -elf flash0.vmlinux.%d: 'root=/dev/romblock%d rootfstype=squashfs ro %s BDVD_BOOT_AUTOSTART=y BAPP_OUT=/dev/console panic=8' >
bst[-1].part_info size< 051 > str< cfe,2,1:rootfs,2,1:vmlinux,2,1:ofefw,2,1:ofews,2,0 >
bst[0].part_info size< 051 > str< cfe,2,0:rootfs,2,0:vmlinux,2,0:ofefw,2,1:ofews,2,0 >
bst[0].bootline_fmt size< 134 > str< boot -z -elf flash0.vmlinux.%d: 'root=/dev/romblock%d rootfstype=squashfs ro %s BDVD_BOOT_AUTOSTART=y BAPP_OUT=/dev/console panic=8' >
bst[0].version size< 041 > str< Ver 1.77 BDX2500 Signed >
cfg.bst_versions size< 004 > i32< 2 >
cfg.version_log size< 216 > str< 0 xxx xxx xx xx:xx:xx xxxx 1.0
+ Wed Jun 11 00:01:33 2008 Signed Encrypt PKG_DVD_3_1_013_04_02_BDX
+ Wed Jun 11 00:02:32 2008 Signed PKG_DVD_3_1_013_02_BDX
+ Sun Dec 25 20:04:20 2011 Ver 1.77 BDX2500 Signed
cfg.launch_successes size< 004 > u32< 3 >
cfg.launch_attempts size< 004 > u32< 3 >
BUPE attempts<3> success<3> revert<0> wr_stats<0>
BUPE bootline< boot -elf flash0.cfe.0: >Loader:elf Filesys:raw Dev:flash0.cfe.0 File: Options:(null)
Loading: 0x87000000/20220 0x87004efc/468 0x87005100/39 0x87007efc/604921 0x8709ba00/16128 0x8709f900/7272
Successfully loaded secure elf image....
Entry address is 0x87000000
Starting program at 0x87000000
BCM76300010
TLB init
Board init
RAM
BCM97630 B0-FULLSEC CFE v2.1.21 (CFE core v2.1, BSP_REV 21), Endian Mode: Little
Build Date: Thu Dec 2 18:15:03 EST 2010 (kdasu@stb-mhtb-02)
Port lock : Enabled
Timestamp started ...
booting ARM...
Reading flash0.ofefw.1 to V:0x80000000 from offset 0 len 1048576
validating ofe fw_ldt@0x800fffa0 ...
Calculated FW checksum: 0x031865c0, LDT checksum: 0x031865c0
parsed fw_ldt@800fffa0 : ws0_sadr=0xc0000 ws0_eadr=0xdffff prodid:BD PLAYER R02
parsed fw_ws @800c0000 : vendor: BROADCOM prodid: BD PLAYER R02
Reading flash0.ofews.0 to V:0x80100000 from offset 0 len 131072
ws partition contains no data
Initializing OFE...ofefw@0x2fd00000
OFE ARM Initialized and held in reset
Elapsed time 504mS (504069 uS)
BUPE attempts<3> success<3> need_to_ask_player_to_increment_launch_successes<0>
BUPE bootline< boot -z -elf flash0.vmlinux.0: 'root=/dev/romblock10 rootfstype=squashfs ro BDVD_BOOT_AUTOSTART=y BAPP_OUT=/dev/console panic=8' >Loader:elf Filesys:raw Dev:flash0.vmlinux.0 File: Options:root=/dev/romblock10 rootfstype=squashfs ro BDVD_BOOT_AUTOSTART=y BAPP_OUT=/dev/console panic=8
Loading:
Successfully verified application....
0x80008000/5108544 0x804e7340/306944
Entry address is 0x8000c870
Starting program at 0x8000c870
[ 0.000000] -- DDR Bank 0: 128 MB
[ 0.000000] -- DDR Bank 1: 256 MB
[ 0.000000] Linux version 2.6.28.9 (root@stbcm-mhtb-1) (gcc version 4.2.0 20070124 (prerelease) - BRCM 10ts-20080721) #664 Fri Apr 29 03:52:23 EDT 2011
[ 0.000000] Kernel command line: root=/dev/romblock10 rootfstype=squashfs ro BDVD_BOOT_AUTOSTART=y BAPP_OUT=/dev/console panic=8 console=0,115200n8 LD_BIND_NOW=on
[4294667.366000] DIGSIG: no valid key, digsig security disabled
[4294667.388000] checker_0 control 0x00000008 addr low 0x00002000 hi 0x003aa000
[4294667.395000] read rights _0 0xffffffff _1 0xffffffff write rights _0 0x00000000 _1 0x00000000
[4294667.404000] checker_1 control 0x00000008 addr low 0x003ab000 hi 0x027fff80
[4294667.411000] read rights _0 0xffffffff _1 0xffffffff write rights _0 0x00000000 _1 0x00e4fca0
[4294667.420000] checker_2 control 0x00000008 addr low 0x20000000 hi 0x238fff80
[4294667.427000] read rights _0 0xffffffff _1 0xffffffff write rights _0 0x00000000 _1 0x00e4fca0
[4294667.436000] checker_3 control 0x00000018 addr low 0x2fd00000 hi 0x2fdfff80
[4294667.443000] read rights _0 0xffffffff _1 0xffffffff write rights _0 0x00000000 _1 0x00010000
[4294667.470000] Driver 'sd' needs updating - please use bus_type methods
[4294667.477000] Driver 'sr' needs updating - please use bus_type methods
[4294667.484000] vide_ofe_probe: FE SECURITY NOT ENABLED
[4294667.552000] Creating 28 MTD partitions on "bcm7xxx-nand":
[4294667.558000] 0x00000000-0x00180000 : "ucfe"
[4294667.564000] 0x00180000-0x00200000 : "drmregion"
[4294667.569000] 0x00200000-0x00280000 : "drmregion.1"
[4294667.575000] 0x00280000-0x00300000 : "rawnvr"
[4294667.580000] 0x00300000-0x00300090 : "macadr"
[4294667.584000] mtd: partition "macadr" doesn't end on an erase block -- force read-only
[4294667.593000] 0x00300090-0x00300800 : "nvram"
[4294667.597000] mtd: partition "nvram" doesn't start on an erase block boundary -- force read-only
[4294667.607000] 0x00300800-0x00400000 : "virtual"
[4294667.612000] mtd: partition "virtual" doesn't start on an erase block boundary -- force read-only
[4294667.621000] 0x00400000-0x00600000 : "cfe.0"
[4294667.626000] 0x00600000-0x00800000 : "cfe.1"
[4294667.631000] 0x00800000-0x00880000 : "vault-a"
[4294667.637000] 0x00880000-0x06080000 : "rootfs.0"
[4294667.643000] 0x06080000-0x06100000 : "vault-b"
[4294667.648000] 0x06100000-0x0b900000 : "rootfs.1"
[4294667.654000] 0x0b900000-0x0bd00000 : "vmlinux.0"
[4294667.659000] 0x0bd00000-0x0bd80000 : "vault-c"
[4294667.665000] 0x0bd80000-0x0c180000 : "vmlinux.1"
[4294667.670000] 0x0c180000-0x0c200000 : "paniclog"
[4294667.676000] 0x0c200000-0x0c280000 : "cfelog"
[4294667.681000] 0x0c280000-0x0c880000 : "splash"
[4294667.686000] 0x0c880000-0x0cc80000 : "syslog"
[4294667.692000] 0x0cc80000-0x0d080000 : "psnv"
[4294667.697000] 0x0d080000-0x0f600000 : "pstor"
[4294667.702000] 0x0f600000-0x0f900000 : "ofefw.0"
[4294667.708000] 0x0f900000-0x0fa00000 : "ofews.0"
[4294667.713000] 0x0fa00000-0x0fd00000 : "ofefw.1"
[4294667.718000] 0x0fd00000-0x0fe00000 : "ofews.1"
[4294667.724000] 0x00300000-0x00400000 : "config"
[4294667.729000] 0x00000000-0x0fe00000 : "all"
rcS: BDVD_BOOT_AUTOSTART<y> BQ<y> BAPP<./app_player> BAPP_OUT</dev/console> BNET<> BNET_DLY<0> OFE_SB<y>
[4294668.512000] yaffs: restored from checkpoint
Mounting pstor, psnv with yaffs2!
rcS: Launch PSTOR mount in background
[4294668.582000] yaffs: restored from checkpoint
[4294668.952000] **>> yaffs chunk 1775 was not erased
[4294668.957000] **>> yaffs chunk 1776 was not erased
[4294668.962000] **>> yaffs chunk 1777 was not erased
[4294668.967000] **>> yaffs chunk 1778 was not erased
[4294668.972000] **>> yaffs chunk 1779 was not erased
(snip about 100 more of these messages)
[4294670.564000] **>> yaffs chunk 2095 was not erased
[4294670.569000] **>> yaffs write required 321 attempts
[4294670.574000] page 1728 in gc has no object: 0 0 0
[4294670.579000] page 1729 in gc has no object: 0 0 0
[4294670.584000] page 1730 in gc has no object: 0 0 0
[4294670.589000] page 1731 in gc has no object: 0 0 0
[4294670.595000] page 1732 in gc has no object: 0 0 0
[4294670.600000] page 1733 in gc has no object: 0 0 0
[4294670.605000] page 1734 in gc has no object: 0 0 0
[4294670.610000] page 1735 in gc has no object: 0 0 0
[4294670.615000] page 1736 in gc has no object: 0 0 0
[4294670.620000] page 1737 in gc has no object: 0 0 0
[4294670.625000] page 1738 in gc has no object: 0 0 0
[4294670.630000] page 1739 in gc has no object: 0 0 0
[4294670.636000] page 1740 in gc has no object: 0 0 0
[4294670.641000] page 1741 in gc has no object: 0 0 0
[4294670.646000] page 1742 in gc has no object: 0 0 0
[4294670.651000] page 1743 in gc has no object: 0 0 0
[4294670.656000] page 1744 in gc has no object: 0 0 0
[4294670.661000] page 1746 in gc has no object: 0 0 0
[4294670.666000] page 1747 in gc has no object: 0 0 0
[4294670.671000] page 1748 in gc has no object: 0 0 0
[4294670.676000] page 1749 in gc has no object: 0 0 0
[4294670.682000] page 1750 in gc has no object: 0 0 0
[4294670.687000] page 1751 in gc has no object: 0 0 0
[4294670.692000] page 1752 in gc has no object: 0 0 0
[4294670.697000] page 1753 in gc has no object: 0 0 0
[4294670.702000] page 1754 in gc has no object: 0 0 0
[4294670.707000] page 1755 in gc has no object: 0 0 0
[4294670.712000] page 1756 in gc has no object: 0 0 0
[4294670.717000] page 1757 in gc has no object: 0 0 0
[4294670.723000] page 1758 in gc has no object: 0 0 0
[4294670.728000] page 1759 in gc has no object: 0 0 0
[4294670.733000] page 1760 in gc has no object: 0 0 0
[4294670.738000] page 1761 in gc has no object: 0 0 0
[4294670.743000] page 1762 in gc has no object: 0 0 0
[4294670.748000] page 1763 in gc has no object: 0 0 0
[4294670.753000] page 1764 in gc has no object: 0 0 0
[4294670.758000] page 1765 in gc has no object: 0 0 0
[4294670.764000] page 1766 in gc has no object: 0 0 0
[4294670.769000] page 1767 in gc has no object: 0 0 0
[4294670.774000] page 1768 in gc has no object: 0 0 0
[4294670.779000] page 1769 in gc has no object: 0 0 0
[4294670.784000] page 1770 in gc has no object: 0 0 0
[4294670.789000] page 1771 in gc has no object: 0 0 0
[4294670.794000] page 1774 in gc has no object: 0 0 0
[4294670.800000] **>> yaffs chunk 2096 was not erased
[4294670.805000] **>> yaffs chunk 2097 was not erased
[4294670.810000] **>> yaffs chunk 2098 was not erased
[4294670.815000] **>> yaffs chunk 2099 was not erased
[4294670.820000] **>> yaffs chunk 2100 was not erased
[4294670.825000] **>> yaffs chunk 2101 was not erased
[4294670.830000] **>> yaffs chunk 2102 was not erased
[4294670.835000] **>> yaffs chunk 2103 was not erased
[4294670.840000] **>> yaffs chunk 2104 was not erased
[4294670.845000] **>> yaffs chunk 2105 was not erased
[4294670.850000] **>> yaffs chunk 2106 was not erased
[4294670.855000] **>> yaffs chunk 2107 was not erased
[4294670.860000] **>> yaffs chunk 2108 was not erased
[4294670.865000] **>> yaffs chunk 2109 was not erased
[4294670.870000] **>> yaffs chunk 2110 was not erased
[4294670.875000] **>> yaffs chunk 2111 was not erased
[4294670.880000] yaffs tragedy: no more erased blocks
[4294670.885000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
[4294670.890000] **>> yaffs write required 16 attempts
[4294670.895000] yaffs tragedy: no more erased blocks
[4294670.900000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
[4294670.905000] yaffs tragedy: no more erased blocks
[4294670.910000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
[4294670.916000] page 1778 in gc has no object: 271 0 0
[4294670.921000] yaffs tragedy: no more erased blocks
[4294670.926000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
[4294670.931000] yaffs tragedy: no more erased blocks
[4294670.936000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
/etc/init.d/rcS: /var/log/wtmp: Cannot allocate memory
cannot access `/var/log/wtmp': No such file or directory
app_ofe_sb: Read current FW image for validation checking
app_ofe_sb: No-Toggle partition name: ofefw.1
[4294671.641000] page 1780 in gc has no object: 259 0 0
app_ofe_sb[4294671.646000] page 1781 in gc has no object: 259 0 0
: Issue SB_IOCTL[4294671.652000] yaffs tragedy: no more erased blocks
_GETCMD
[4294671.658000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
[4294671.665000] page 1783 in gc has no object: 259 0 0
[4294671.670000] page 1784 in gc has no object: 259 0 0
[4294671.675000] page 1785 in gc has no object: 259 0 0
[4294671.681000] yaffs tragedy: no more erased blocks
[4294671.685000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
[4294671.691000] yaffs tragedy: no more erased blocks
[4294671.695000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
[4294671.701000] page 1787 in gc has no object: 259 0 0
[4294671.706000] page 1788 in gc has no object: 259 0 0
[4294671.711000] page 1789 in gc has no object: 259 0 0
[4294671.717000] yaffs tragedy: no more erased blocks
[4294671.722000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
[4294671.727000] page 1791 in gc has no object: 259 0 0
[4294671.732000] yaffs tragedy: no more erased blocks
[4294671.737000] !!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
syslogd: /var/log/messages: Cannot allocate memory
syslogd: cannot create /dev/log: Address already in use
