Author Topic: Toshiba LTM08C015KA LCD datasheet and reverse engineering - FPGA VGA output  (Read 2242 times)
Offline adilmalikTopic starter
Hi Everyone,
Recently I posted about fixing my HP 54542Cs LCD, turned out to be something simple in the end. Due to the nature of the damage, I dont know how long the LCD will last, so I want to reverse engineer the protocol and add a custom FPGA based VGA output. This way I can also support other LCDs if this one dies.
The LCD in question is a toshiba LTM08C015KA. This is used in the HP54542C and the Anritsu MT8801B Spectrum analyser. Unfortunately, I cannot seem to find a data sheet for it. At first glance it looks like a 18-bit RGB protocol. Does anyone have more info or a datasheet for this lcd?
Offline marshallh
    • retroactive
Very easy as long as you have a working example. Get a multichannel logic analyzer and tap everything while it runs. Once you find the digital RGB lines you can ignore all but a few of those, and focus your efforts on the control signals. Either it'll be Hsync/vsync controlled, or DE only.
You could also use a FPGA with Signaltap based on the display's pixel clock to capture exact timings.
Verilog tips
BGA soldering intro
Offline Testtech
It too have an HP scope using this display. Any progress on this retrofit?
Offline Rasz
    • My random blog.
