@coromonadalix, yes I agree, after reading the posts and seeing the circuits I think my circuit diagram I have is incomplete and incorrect. I should've taken the board out and trace sketch my own circuit diagram. Apologies. I also did not understand how it could give 3Amps...
@lowimpedance, thank you for highlighting that there are multiple versions, I believe I found mine amongst the ones you shared. The unloaded voltage is 5.042V and I used a 150A50mV shunt resistor to determine the max current given, so basically no load voltage. Got a rating of 2.5mV on my 87V, which equates to 7,5A of current in this case.
@floobydust, that image is the supply I have, I haven't traced the circuit myself, I should've! Stupid of me to forget about test lead resistance, they only give me 0,1 Ohms extra resistance. I will check R303 and 2SA699 later this evening and get back to you. Yes the LED does light up.
