FYI I have ordered a 2nd hand unit as I have no idea about these boxes.
Anyways, I have a parking control module that just beeps continuously, started happening one day out of the blue, I unplugged all of the parking sensors and it just kept beeping still, I removed the unit from the car and popped it on my bench for further inspection.
Seems to be 4 x circuits with transistors and some kind of inductor / transformer and some misc circuitry for power and buzzer.
I hooked it up to a 12V bench supply, the 4 x sensor inputs all appear to be connected to ground, two pins per input, not sure if this is correct?? Seems connected to GND with power on or off, not hooked it up to a scope so not sure if it is generating any signal (40KHz for Ultrasonics?) all 4 seem the same so I guess this is correct operation?
The buzzer output has a permanent connection to ~12V so is always on, none of the transistors seem shorted, not inspected it that closely, done some basic probing.
I presumed that with nothing connected it should be silent - or so the forums suggest.
The unit is a Toyota branded Cobra unit 4m0168T1A, or Cobra part code 4m0168a1c.
I can find posts with the same issues and the end result is change the control unit, but not much on how to fix or what might be wrong.
So, if anyone has any information on a possible fix for these things then do please tell, can't find any useful information about it.
I've seen one image with coloured splodges on the 3 electrolytic caps and the 4 x EPCOS branded inductors / transformers, all 4 outputs seem to buzz out the same and seem to give the same output, the caps measure OK.
I could hear a slight fluctuation in the tone when plugged into the sensors and covering it, but the constant buzz saturated it so not sure if the output is shorted on, or if there is a logic fault.
I can take a picture of the circuit board if it helps?
EDIT:
https://ibb.co/0yPbJVTImage of board.
TIA!
