Hi ppl,
i have a lcd tv which suffered lightning strike, red diode is on but you can not power on the tv it is not possible to switch it on. I did some work and i believe i have diagnosed it correctly. Board is TP.MS3463S.PB801 and main chip (they call it lcd chip but for me it is microcontroller or maybe microprocessor) is MSD3463GSA. Very soon as you plug it to the wall the chip gets hot maybe in a minute, i did some voltage checks and looks like all arround the pins the voltage is 3,4v suggesting internal short in the chip, also some voltages are missing for example 1.15 or 1.something v. Since markings on the diagram are poor and there are some abbreviations which i am not familiar of i am stuck and cant figure out what are the inputs and what are the outputs but i am pretty sure the chip is gone. I assume that most of 5v and 3.3v are voltage regulated power supply and those voltages of 1. and 0. v are probably outputs of a chip, am i right?
Looks like other stages are just fine there is power to the usb and hdmi ports, there is power out of the switcher looks like the levels are correct, so it looks like the chip itself is bad, but before i test the rest and change the chip eventually i need to know how hard is to change the chip?
I guess it has to be programmed?
Do you need special equipment?
Can you buy already preprogrammed chip for that specific board?
Can it be programmed on the board or has to be on the bench?
Help and advices are apprecieted.
Thanks.
