Hello all,
yesterday i received the spare part and i replaced the regulator now the 3.3V are present this means that i fixed the root cause but unfortunately I'm facing an issue during the memory programming. let me sum up the test that i performed:
- I soldered the memory chip in the adapter provided with ch341a, i double checked the connection and every thing it's ok but when i'm going to program the memory i faced a writing issue and the process aborted
- I tried with two different flash but same issue
- i tried with both imsprog and asprogrammer
- i tried to read and flash a different flash and i was able to complete the writing properly
- i read the sre register and the WEL flag is 1 this means that the chip is writable according to the datsheet
- i tried to delete the flash content and workded fine
- when i try to write some content the programmer face error writing sector 0x0000000
- i tried different programmers ch341a, neoprogrammer, asprogrammer colibri341 but same issue seems that the new chip is detected erasable but for some reason i'm not able to write the dump.
i also tried to put some random content in the memory like 33 but nothing worked.
i double checked and the WP pin is at 3,3V this means that the chip is writable...
I suppose that the memory is working but i'm missing something any suggestion ?
Thanks
------UPDATE -----
insiting with ch341a software i was able to flash the data i disconnected the programmer than connected again , read the content and seems the flashimage expected but same issue no boot ethernet flash are solid and not blinking .
I will double check if the content is present but i have to desolder the flash. if the content is confirmed i saw only two option_
- CPU compromised (how to test it ?)
- wrong software
the CPU is an est e1868m4b but I cannot find the datasheet could someone help ?
