Thank you, this is what I want to try to do. Now, here is an interesting question. Previous computer SMPS was also subject to annoying whine and one day just blew up. After replacement with another power supply whine seemed much reduced, now its getting bad again. Is there any chance that this issue may be the result of a bad interaction between multiple components, bad combination of driver software and hardware, or failing component not in the power supply, but causing - perhaps it may have been the cause of the last PS failing?
Its a standard PC, with an old motherboard, two not too old video cards, and a new (Corsair) power supply. The blown out power supply was a Rosewill "Green" supply.
It gets better sometimes, its better, almost inaudible, when its first turned on.
the motherboard is old.
