Author Topic: Transformer  (Read 1176 times)
Offline AirScooterTopic starter
Transformer
« on: March 31, 2021, 06:10:27 pm »
This is the schematic of the power supply on my Fluke 8000A Bench Multimeter.
The transformer gave up the ghost after 50 years of service. I'm trying to find a replacement for it.
It's a through hole mount 5 studs through the board to a side. The output side has one stud cut off. It outputs +5v and +15v DC, 115AC mains.
The Fluke part is #345629. (No longer supported by Fluke) The Manufacture Supply Code is 89536. I am looking for a physical size in the manual but so far coming up short. If you need more/different information let me know.
Thanks,
Dave Lowa
Offline bdunham7
Re: Transformer
« Reply #1 on: March 31, 2021, 06:24:04 pm »
Can you post a photo of the board and the revision number?
Offline DLJ
Re: Transformer
« Reply #2 on: March 31, 2021, 06:53:11 pm »
Which transformer do you suspect? The schematic you have attached has two.
T1 is used to generate 5V, and T2 is used to generate +15V and -15V from that 5V.
Does the meter still work on battery power?
It would appear that there are at least 3 different variants Of the Fluke 8000A - the service manual show the schematics for these. Each has a different PSU. Which one do you have?
« Last Edit: March 31, 2021, 07:22:02 pm by DLJ »
Re: Transformer
« Reply #3 on: March 31, 2021, 09:14:51 pm »
Super Question, but we'll have to wait till tomorrow to find out. Have to wait for the supplier and his questions to get back in the office.
Re: Transformer
« Reply #4 on: March 31, 2021, 09:32:05 pm »
Here you go bd..........
Thanks for your help!
1206656-0
1206660-1
Offline bdunham7
Re: Transformer
« Reply #5 on: March 31, 2021, 10:17:25 pm »
You have the wrong schematic.  How do you test the transformer?
Offline bob91343
Re: Transformer
« Reply #6 on: March 31, 2021, 10:46:01 pm »
The OP's diagram shows a battery operated unit; the battery runs a square wave oscillator that generates the voltages for operation.  The diagram above shows no battery, just a simple TR with simple regulators.
