Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Transistor BFY90 replacement / equivalent
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Transistor BFY90 replacement / equivalent (Read 1002 times)
Wawavoun
Regular Contributor
Country:
Someday I'll get you, Red Baron !
on:
October 07, 2021, 10:52:53 am »
Hello there,
In the following circuit I replace the BFY90 by a 2N2222.
The highest frequency come from the shift register LS165 and is 16 MHz.
Will the assembly work with same performances with this change ?
With the datasheets I think yes but I am unsure.
I have no measurement system at such frequency. My scope is 20 Mhz bandwith so it show nothing serious at 16 MHz.
Thanks for help and explanations.
Regards.
Philippe
Logged
Kleinstein
Super Contributor
Country:
Re: Transistor BFY90 replacement / equivalent
Reply #1 on:
October 07, 2021, 11:53:28 am »
The BFY90 is quite a bit faster and lower capacitance than the 2n2222. So it would be a bit slower. The input side looks like is is reasonable low impedance, so it may still work, but it depends on what the ouput is used for.
Logged
Wawavoun
Regular Contributor
Country:
Reply #2 on:
October 07, 2021, 12:09:09 pm »
The output feed the composite video input of lcd tv.
Today the tv (which works well with similar others systems) dont show anything.
All the board is new and debugging is on the way but far from finished so I do not incriminate the 2N2222 at this moment.
Logged
Kleinstein
Super Contributor
Country:
Reply #3 on:
October 07, 2021, 01:57:38 pm »
Composite video should be OK, as the frequency is limited (AFAIR some 6 MHz). So a slightly slower transistor should not be a problem.
Logged
edavid
Super Contributor
Country:
Reply #4 on:
October 07, 2021, 03:45:10 pm »
A 20MHz scope is fine for debugging this. If the SR is clocked at 16MHz, the maximum output frequency is 8MHz.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
