Came to me with a shorted / failed TR405. I've replaced it (with a trusted part, even swapped for known good) and it seems to run hot. I find myself not really knowing enough about this circuit to fully understand if there is an issue or not. Here are the facts of the case so far.
With my Fluke hooked up between the output of the regulator and the rest of the circuit, it pulls about 140mA.
Schematic shows +13V rail feeds
only the
AM/FM tuner circuits
and the
LED driver for the AM/FM signal strength indicator. So... here's my list of questions:
Does either AM or FM work?AM/FM section contains 2 IC chips which receive 13V power no matter what position the input selector switch is in. The main IC in the AM/FM tuner is
IC201 (HA11211). It has series resistor
R218 (22 ohms). Voltage drop across R218 should be <1V, which corresponds to
~40mA. If anything is wrong with IC201 you won't hear FM at all, perhaps no AM either.
If FM works: Does stereo indicator turn on when tuned to a strong FM station which is known to be transmitting in stereo? And does the stereo indicator turn off when not tuned to a station?
The FM stereo decoder IC is
IC202 (MC1310P or AN115). Series resistor is
R268 (47 ohm). Voltage across R268 also should be <1V. This works out to
~20mA.Does signal strength LED bargraph work? EDIT: Another eevblog user informed me the LB1405 provides ~5mA to each LEDIt's current drain depends on
how many LEDs are on at same time. Each LED takes
~10-20mA. ~5mA So,
total current with 5 LED "on" will be ~30mA. When no LEDs are lit up this board should draw very little current, likely <5mA. I haven't looked at the datasheet for IC801 (LB1405) yet but one of the resistors connected to it may control the LED current. So if these LEDs are brighter than they really need to be, then changing the correct resistor might dim them a bit. The human eye has a logarithmic response to brightness. Therefore reducing LED current by half makes them get only slightly dimmer to the human eye.
There's a few mA that go elsewhere in the AM/FM tuner section, but adding this to what IC201 and IC 202 take suggests the
total for the AM/FM section is ~70mA Interesting: Adding in the LED bargraph current (~30mA) for when all 5 LED are "on" gives a grand total of
~100mA.To conclude, your measurement of 140mA isn't terribly out of bounds, but it certainly is higher than expectedPerhaps isolating one section at a time is a good plan: - Temporarily disconnect +13V rail from LED bargraph PC board. This terminal is marked 1 on schematic
- Temporarily remove one end of R218 (22 ohms) and one end of R268 (47 ohms)
-Now how much current is being taken from the +13V supply rail?
There is a possibility that if AM, FM, FM stereo, and the LED bargraph
are all functioning perfectly, then 140mA might be "normal" for this receiver. Back in the day they did press these linear regulator circuits hard. In my experience it is completely normal to see "darkened" PC board substrate in these linear regulators. And these regulator transistors like TR405 do run "hot to the touch."
As to whether you wish to modify this regulator circuit to beef it up, one must ask
"If it didn't break until it was >30 years old, then how much better does the circuit design really need to be?
