Author Topic: Tried to repair my girlfriends iPhone and messed up a bit :-/  (Read 5007 times)
Offline Rodast
« on: September 05, 2013, 11:46:16 am »
Hello All,
I tried to replace a broken power switch on my girlfriends iPhone yesterday which regularly is not such a hard task to accomplish and videos on youtube are such a great guidance that practically nothing can go wrong.
Everything went just fine until I started to reassemble things and managed to glitch with the screw driver while meaning it a little bit to good to get one of the last screws fastened.  :wtf:
So I kicked a tiny little resistor? right off the mainbord.  Go figure :rant:
To my great surprise the phone booted up and until now I received no complains or worse as feedback after this repair try.
What is that part and are there any later damages to be expected (should I start saving on a replacement) now that it is missing *sigh*
Greetings
Rodast
« Last Edit: September 05, 2013, 11:52:05 am by Rodast »
Offline firewalker
  • Country: gr
Re: Tried to repair my girlfriends iPhone and messed up a bit :-/
« Reply #1 on: September 05, 2013, 11:55:13 am »
It looks like a resistor. Probably a pull-up/down resistor or a jumper. You really can't be sure for the consequences without a schematic. If it works for a week or so without problems...
Alexander.
Offline Psi
« Reply #2 on: September 05, 2013, 12:15:49 pm »
If it works fine don't worry about it.
If you really want to test the phone, and see if you can find any issues, i would start by looking at where those 5 nearby connectors go. If they each go to a sensor or module then you have some functions to start testing.
« Last Edit: September 05, 2013, 12:21:28 pm by Psi »
Offline Rodast
« Reply #3 on: September 05, 2013, 12:40:50 pm »
I did some more invesigation and the tiny piece seems to be an FL21 or in other words a filter for the front VGA camera.
So I guess as soon as this camera will be tried out again I will get what I deserve ;-)
Luckily it doesen't seem to be one of the most frequently used parts on that phone.
If it were my own device I would probably just jumper it to get it working again....
Offline amyk
« Reply #4 on: September 05, 2013, 01:26:09 pm »
FL21 - filter choke for 2.85V supply to camera.
A jumper across it may be OK, or you can just find a suitable replacement like this:
http://www.digikey.com/product-detail/en/BLM03AG100SN1D/490-2555-1-ND/610981
Offline dfmischler
« Reply #5 on: September 05, 2013, 01:37:01 pm »
Aw, are you saying she loves her iPhone more than she loves you?   ::)   Besides, she probably doesn't have anything important to take pictures of, anyway.
Offline Psi
« Reply #6 on: September 05, 2013, 02:34:15 pm »
My phone has a front camera but ive only used it once and that was to see if it actually worked. :D
Offline DarkPrince
« Reply #7 on: September 05, 2013, 02:52:18 pm »
Surely she already knows of the misfortune during the repair due to when you told her, correct? Nothing to worry about. Mistakes happen.  :D
Yeah phone cameras are overrated (ish).
Advertise on the EEVblog Forum
