Hello,
Did you repair the -8,010,311 error code what did you find? I have one with OPT. 001 with a similar same code (-8,010,310). Also no signal on the rear panel 10MHz Ref. Out.
Have a replacement REFERENCE module on the way but now thinking the problem is elsewhere.
Any tips on how to disassemble for access the 10MHZ Reference Osc. (A20 location)?
Thanks
