I have had some similar experiences. Unless you have a lot of free time and nothing better to spend it on my guess is that chances are you will waste much time and not get far. From a practical point of view I would suggest finding a pro.
Now, assuming you have time and do not mind wasting it, you need to understand the controller board is not just some basic electronics but a programmed controller.
When it starts up it goes through a routine of checking parameters here and there, waiting for this and that, and it will usually take several minutes before it even tries to start up the compressor. Troubleshooting the board without having complete documentation will be very difficult. You can try all the sensors and other inputs. You might get lucky and find something easy and obvious. Go over all the wiring, connections, etc and make sure everything is as it should be.
I had a unit fail under warranty a couple years ago and the guy came out and replaced both boards (inside and out). He told me the boards are not worth repairing as he, with all his knowledge, could spend hours on each board and only be able to repair a small fraction of them. Not worth it.
A different issue which happens often is refrigerant loss. If the system is not absolutely tight then it might lose some refrigerant. Especially some of the newer refrigerants work at higher pressures and will leak more easily. A pro has the tools and knowledge that he can check this in a matter of minutes and it is not something that it is worth your time or effort.
