Author Topic: [Solved] Troubleshooting select EEPROM configuration!  (Read 1260 times)
Offline AkibUddinTopic starter
  • Be proud of who you are
« on: December 02, 2022, 03:03:14 pm »
Richmeter RM219 has P24C02A eeprom, so if i use 24c02 eeprom then have any problem ? P24C02A bidirectional data transfer speed 1mhz & 400khz other side 24c02 eeprom has 400khz & 100khz ..  :blah: :bullshit:
« Last Edit: December 09, 2022, 02:14:59 am by AkibUddin »
Best regards,
Akib Zabed
Offline coromonadalix
Re: Troubleshooting EEPROM Error !
« Reply #1 on: December 02, 2022, 04:10:03 pm »
your thread is confusing and i would say  not indicative
are you talking about  eeprom wear and tear,  read and write cycles,   life expectancy before failures, data corruption  ?
Online wraper
  • Country: lv
« Reply #2 on: December 02, 2022, 04:18:36 pm »
Both are "24C02" which is a generalization. Second one not being specific about what it actually is, there are a ton of different 24C02. Generally all 24C02 are mostly compatible but there may be differences which can be an issue in some cases. The issues may be with operating voltage range, presence of adress pins (if not all of them are connected to GND), maximum clock frequency if a high clock speed is used in particular device. Also they may have different maximum page write size. Generally all of that is not an issue, however device may be deing something out of particular IC spec.
As of max I2C speed, it's very unlikely this meter uses over 400kHz.
« Last Edit: December 02, 2022, 04:33:11 pm by wraper »
« Reply #3 on: December 04, 2022, 12:53:18 am »
:-// confusing about eeprom selection when original get corrupted :scared:
Best regards,
Akib Zabed
« Reply #4 on: December 04, 2022, 12:57:09 am »
You got the issue  :-+
Best regards,
Akib Zabed
« Reply #5 on: December 09, 2022, 02:12:06 am »
Here still using 2 different  type eeprom in same multimeter |O 24c02a has 1M to 400k Other hand 24c02n has 400k to 100K bidirectional data transfer speed. Booth still working [Solved] Aneng M118A
« Last Edit: December 09, 2022, 02:15:56 am by AkibUddin »
Best regards,
Akib Zabed
Online wraper
  • Country: lv
Re: [Solved] Troubleshooting select EEPROM configuration!
« Reply #6 on: December 09, 2022, 01:57:21 pm »
Nope, all of them have speed range starting from basically 0 Hz. Initial I2C standard allowed maximum of 100kHz, later standards increased it to 400kHz and 1MHz. Mentioning higher clock figures means that chip adheres to later standard.
