Author Topic: Troubleshooting HP 8903A Audio Analyzer input  (Read 182 times)
Offline MWH901Topic starter
« on: August 06, 2024, 06:36:00 pm »
Hello... I'm working on an 8903A which is exhibiting odd behavior. Using an external signal generator and just exercising the input/analyzer functions, I have encountered a scenario where distortion increases and signal input voltages read incorrectly low, but only within a certain range, maybe ~3.5V - 12V.
For example, using auto-ranging, a 5.0V 1kHz input signal will read 4.69V on the display at a THD of 6.41%.
However, when use 1.7SPCL to force the unit into the 18.9V input range, that same 5.0V input signal reads properly as 5.0V and .02% distortion.
I'm having a hell of time figuring out where/how that distortion is getting introduced within that particular range. I did look at the distorted waveform on the scope, and the bottoms of the sine wave seem a bit rounded off... maybe a sagging negative voltage rail somewhere?
Thanks in advance...
-Mike
