Author Topic: Troubleshooting LCD monitor LED backlight circuit  (Read 25171 times)
Offline RevenantTopic starter
« on: May 18, 2015, 05:20:21 pm »
I have an LCD monitor that's having backlight problems. The backlight will cut out for a split second at a time randomly, and I notice it flickering on certain backgrounds. I have a second identical monitor (dual screen setup) which doesn't have this problem. The problem is temperature correlated, when the monitor has been powered off in a cold room overnight the issue is exacerbated until it warms up. This initially led me to believe capacitors were at fault.
Steps taken to isolate/attempt to fix the problem:
    Measure 5V and 12V rails on SMPS. Within spec.
    Replace all capacitors on SMPS board except input filter with equivalent spec/ESR quality brand ones (panasonic, nichicon, etc)
    Problem persists, desoldered input filter and test, tests ok.
    Look up datasheet on LCD panel itself and find backlight connector pinout/voltage ranges. Says 46-56V.
    Attempt to look up backlight boost driver IC datasheet, but cannot find it anywhere.
    Attempted replacing all lelon/capxon/suscon electrolytic capacitors on the second PCB that has the processor on it. No dice. All but one tested ok with LCR/ESR meter once desoldered.
    Soldered test wire onto boost converter vout pin. Voltage comes in at 58-65 volts. Voltage changes inversely with brightness control. Full brightness = 58V, 0 brightness = 65V. When monitor goes into power saving, voltage jumps up to 75V. In comparison, the good monitor measures ~50V at full brightness, drops down to 48V at 0 brightness, and <30V when power saving.
    Unfortunately the good monitor was outsourced to a different manufacturer for the SMPS and processor board, so the only things interchangeable are the LCD panels themselves. I already confirmed with an LCD panel swap that the issue is not the LED strings themselves.
I have been attempting to find the IC by searching for terms like "4 channel LED string boost" and such, but application schematics all differ from the circuit on the PCB. The output side of the IC on my monitor has 4 diodes, 4 film capacitors, and 4 inductors. The schematics I see in boost driver ICs online all just show one diode and inductor, even on 4 channel ones. I guess my next step is tracing the pcb and drawing a circuit. I tried testing the diodes and inductors in circuit and they seem to test ok.
Anyone have any other ideas of things I can try? Unfortunately, I don't have an oscilloscope, so I can't look at the waveform.
Offline nctnico
Re: Troubleshooting LCD monitor LED backlight circuit
« Reply #1 on: May 18, 2015, 05:33:12 pm »
I'd get a can of freeze spray. Start by spraying sections of the PCB and then by individual components to find the fault.
« Reply #2 on: May 18, 2015, 05:42:39 pm »
Good idea, I'll grab some canned air when I'm out this afternoon.
« Reply #3 on: May 18, 2015, 09:12:18 pm »
No FREEZE spray.
Post up pics of the Backlight controller IC, quite likely we'll be able to help.
Avid Rabid Hobbyist
« Reply #4 on: May 18, 2015, 10:34:14 pm »
No FREEZE spray.
Can't get that locally so I'll have to order it online. I figured air would work since I've seen repair videos where they turn it upside down to chill a component in the process of troubleshooting. I'll get a picture of the IC.
« Reply #5 on: May 18, 2015, 11:30:14 pm »
Here are some pictures of the IC and the traces going to the edge connector. The best code(s) I could get off it was OK(M?)9907O(0?)N on the top, and M28A3 on the bottom. The bottom code only comes up with assault rifle hits from call of duty.
« Last Edit: May 19, 2015, 08:45:56 pm by Revenant »
Offline Rasz
    • My random blog.
« Reply #6 on: May 19, 2015, 11:26:16 am »
blurry pictures, second diode looks fried
« Reply #7 on: May 19, 2015, 08:56:14 pm »
My camera isn't the best. I upped the fstop to alleviate the focus issues and retook in better lighting. Hopefully these are better. I don't have any kind of macro lens so this is the closest pictures I can get of the IC before it can't focus on it due to being too close. The writing is really worn down so I'm afraid this is as good as it gets.
I tested all diodes in circuit and none showed a dead short in the opposing direction and the same voltage drop in the forward direction.
I think I may have goofed in measuring the voltage of the LED backlight v+ supply (sorry, I am a beginner and not familiar with boost converter circuits). I referenced to system ground and after reviewing example led backlight IC application circuit schematics I realize that it probably should have been to the current sink channels instead? When I measure to those they show up as 44v instead of 60. I can try to trace the connector pins back to the IC and post the resulting schematic if that would help any.
« Reply #8 on: May 19, 2015, 09:00:42 pm »
Rasz is very good on this sort of stuff, but we have to identify the baclight controller IC FIRST.
The datasheet should reveal the mystery.  ;)
Avid Rabid Hobbyist
Offline thm_w
  • Non-expert
« Reply #9 on: May 19, 2015, 10:16:04 pm »
Canned air is fine.
Offline Rasz
    • My random blog.
« Reply #10 on: May 20, 2015, 05:26:29 pm »
Easy way: http://www.ebay.com/itm/Universal-LED-Constant-current-board-LED-Inverter-Boost-Board-for-LED-Panel/181557989682
= 15s4p, this controller will work fine, thats what I use
some ukrainian dude fixing tv with it
those markings look highly custom/cryptic :(, from your defect description sounds like one of the smd caps or solder joints might be dying and intermittent, also whats with yellow around second IC on last picture? is that your flux or cooked pcb?
redo all the small smd parts with your soldering iron around that mysterious IC, hmm redo all IC legs too while you are at it. But it also might be 12V dropping from time to time and not the backlight controller at all. That yellow pcb looks suspicious.
« Reply #11 on: May 20, 2015, 09:18:25 pm »
There are no capacitors around that suspect yellowed area, so it is not flux. You're right, it looks like something got cooked there. I tried to look up the datasheet for that IC but it is another cryptic one that comes up with no hits. line 1: 1920MP, line 2: 12801K. In that area is a schottky diode (sx34). In circuit diode test with multimeter shows .184 voltage drop and 180 ohms on the resistance setting. The discoloration seems to be centered around a big ferrite inductor on the other side of the board which is discolored a bit as well, but it tests to 10uH which is its rating.
Unfortunately my soldering iron isn't fine enough to get into some of those SMD parts so i'd probably make things worse attempting to resolder them. I could try with the bigger areas though. I will also try the freeze test with the canned air since thm_w indicated it should work fine.
That hong kong board looks like it might work but from the youtube video, it appears you have to connect some lines to the right spot in order for the brightness controls to work properly?
« Reply #12 on: May 21, 2015, 10:01:42 pm »
Ok, did some more testing, no real progress. |O
I measured the brightness adjustment line with my multimeter. It shows a range of ~.1v to 3.28v or so. Duty cycle ranges from 10% at 0 brightness to OL at 100% brighness. Peak min/max function (closest I can get to a scope) shows .1v min and 3.28v max, which I guess is consistent with a pwm signal. It doesn't appear there's any issues with that signal.
Tried freezing things to see if I could induce the problematic backlight behavior, and zero results. I first targeted the suspect yellowed area IC and surrounding diodes, nothing. Then I targeted the backlight boost IC, froze it, nothing. I then tried freezing various chips on the other PCB and still could not recreate the problem. 12V rail reads as low as 11.83 at times but if the IC takes a wide range of input voltage then I doubt that would cause the problem.
I guess I can order that hong kong board since it is only $8 shipped. If that doesn't fix it looks like I'm out of options.
EDIT: The hong kong board states 0V is brightest, and 5V is darkest. "(0V-5V, the brightest 0V, the darkest time 5V) brightness adjustment"
That is opposite to and a different voltage range than this monitor (~0V darkest, 3.3 brightest). It doesn't look like that would work.
« Last Edit: May 21, 2015, 10:07:45 pm by Revenant »
Offline wraper
  • Country: lv
« Reply #13 on: May 21, 2015, 10:17:50 pm »
Crappy photos with some characters invisible but I figured out that it should be OZ9902B
« Last Edit: May 21, 2015, 10:26:42 pm by wraper »
« Reply #14 on: May 22, 2015, 12:16:29 am »
Thank you for your efforts in trying to find this IC. Unfortunately, the characters are invisible/highly worn down on the chip itself, so it wouldn't matter which camera I used, I did the best I could with what I have available.
The 9902B is a single channel led driver, according to the LG panel datasheet, it requires 4 channels. The 6 pin cable that connects to the backlight is:
BACKLIGHT CONNECTOR PIN CONFIGURATION(CN2)
1 Channel1 Current Feedback
2 Channel2 Current Feedback
3 LED Power Supply
4 LED Power Supply
5 Channel3 Current Feedback
6 Channel4 Current Feedback
I thought it might be the 0Z9998B, but the pinouts don't match. It is a 16 pin ic with pin 14 as GND and pin 11 as vin (I think, measures 10ohms to 12V rail). On the PCB, there is an inductor, capacitor, and diode for each of the 4 channels. Maybe that is an alternative layout than the single inductor and diode I see in all the applications schematics?
Offline wraper
  • Country: lv
« Reply #15 on: May 22, 2015, 08:21:47 am »
Did you try to clean it with alcohol/acetone? Laser markings usually become invisible because some flux or dirt gets into them, when cleaned they usually become clearly visible again. Your IC just looks dirty IMO. By looks of it, could be also OZ9907GN. But I cannot find a datasheet for it. Anyway, it is 100% made by O2micro. Also, why didn't you say a monitor model?
« Last Edit: May 22, 2015, 08:32:02 am by wraper »
« Reply #16 on: May 22, 2015, 11:43:28 pm »
Alcohol did indeed reveal the "worn down" (dirty) markings! I remember I had heard that tip a long time ago but had forgotten to try it. I can now read the entire chip text and as you surmised it is indeed OZ9907GN. I do find links to this chip but no datasheets anywhere, unfortunately.
I was focusing on all the other details and forgot to post the obvious - the monitor is HP zr2440w, and the panel is LG LM240WU8-SLA1.
It doesn't look like I can really make much further diagnostic progress without a datasheet or scope.
« Last Edit: May 22, 2015, 11:47:43 pm by Revenant »
Offline wraper
  • Country: lv
« Reply #17 on: May 23, 2015, 09:38:34 am »
Test those film capacitors, preferably with desoldering and checking if they are not leaky too. Maybe even just change them, especially if one of them has lower capacitance than 3 others.
« Reply #18 on: May 26, 2015, 02:14:19 am »
I don't have a mega ohm meter/capacitor leakage tester so I can't test if they're leaky. All 4 are 100nF capacitors. I've desoldered 3 and they all come in at 96-98nF when tested. Will test the last one later. Maybe it's the IC itself that's bad, but even if I could get a replacement IC I don't have an smd rework station so it wouldn't be possible anyway. It's too bad that backlight replacement pcb linked earlier isn't compatible with my panel.
I'll see if I can figure anything else out with tracing, for example I'm not sure that 4ohm from the IC pin to the 12V rail is normal.
Offline Rasz
    • My random blog.
« Reply #19 on: May 26, 2015, 06:12:13 am »
sure it is, it might not be 100% compatible with the driver, but whats a little backwards not dimming all the way down brightness control among friends? :)
if it really bugs you that much build one transistor inverter to translate control signal
edit:
btw http://www.badcaps.net/forum/showthread.php?p=557450
is that also your post? or did DELL made a bigger oopsie
« Reply #20 on: May 26, 2015, 07:29:33 am »
I wasn't sure if the voltage mismatch (5v vs 3.3v) would cause problems with frying anything. I usually keep brightness at 20% (anything higher hurts my eyes), so if it is inverted and 5v instead of 3.3, 20% brightness setting translates to ~4v, so it looks like I'd need to construct a circuit that increases the voltage as well as inverting. There is already a 5v rail so maybe that wouldn't be too difficult?
I don't understand the DELL reference. Is there a forum policy against posting on other sites ("oopsie")?
Offline Rasz
    • My random blog.
« Reply #21 on: May 26, 2015, 09:22:03 am »
https://learn.sparkfun.com/tutorials/transistors under Common Emitter
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/npnce3.html#c1
either its your post, or dell sourced shitty batch of monitor internals and they are faliling everywhere
Offline wraper
  • Country: lv
« Reply #22 on: May 26, 2015, 09:59:31 am »
Do you mean hot air station? You don't need it and actually it is dangerous to use on phenolic PCB. Often it makes a bubble (expanding moisture) if heated with hot air. Just cut the leads of the old IC. then remove the remains of the leads with soldering iron. Then solder new IC. Possible to remove even without cutting the leads, just apply low melting point Wood's metal/Chip Quik alloy or just huge amount of solder (a bit harder) to all of the leads and heat the opposite sides fast, then quickly remove the IC before solder solidifies.
http://www.aliexpress.com/item/OZ9907GN-SOP/1881985728.html?spm=2114.32010308.4.2.txgmug
« Reply #23 on: May 26, 2015, 10:06:56 am »
Thanks for the references, I will review them and see if I can construct the circuit.
Yes, I posted over there. My monitor is HP, not Dell. In my searches I've come across other posts about this particular power board used in the earlier revision zr2440w monitors, so they probably are crap quality.
« Reply #24 on: May 26, 2015, 10:14:02 am »
but even if I could get a replacement IC I don't have an smd rework station so it wouldn't be possible anyway. it is too bad that backlight replacement pcb linked earlier isn't compatible with my panel.
Yes, I meant hot air rework. I did not know it was dangerous to use on this type of PCB, thanks for the heads up. Though upon further review I am thinking it would probably be better to replace the mystery 1920MP/12801K chip first, given the scorching discoloration on the PCB in that area.
« Last Edit: May 26, 2015, 10:23:33 am by Revenant »
