Wow yes, I had no idea about carbon print resistors. I've spent literally hours looking for those resistors, and they're just those little black squares on the board?
Anyway, I measured R27 to be 268R, and there are 12.4V before and 10.7V after it. Is that too much current draw? Upstream is the same as on schematic, but voltages at IC 1 and 2 are about 10-15 percent lower than on the schematic. I checked again for R33 and resistance between emitter and R27 is 0.5R, so I think R402 doesn't exist. After disconnecting the tape heads, I measured 91.7k for R7 and 95.5k for R8. Is it worth scratching through them and replacing them with new, through-hole parts?
Also, I noticed that the rail gets really noisy when I activate the transport, and the noise appears on the scope together with the noise on the headphones. At idle, the upstream side is fairly smooth (with muting circuit activated), I've attached a video where you can see what happens when I press play.
Here's the video link
https://youtu.be/q1yeR-zrywsTop trace is before R27 and bottom trace is after R27, at maximum scope gain, 1mV/div. I tried disconnecting the motor to see if that helped and it becomes very noisy even at idle with the motor disconnected.
Could the headphone amp be drawing too much current or something? Should I try disconnecting the headphone amp by lifting a leg of R99 and R100? Also, the player takes almost two seconds to unmute, is this a useful clue? And what can I do to improve it, is it likely a dying electrolytic cap?
