Author Topic: Tek 2445 issue with CH2  (Read 163 times)
Offline giosifTopic starter
« on: Yesterday at 05:03:15 pm »
Recently, I got my hands on a broken Tektronix 2445 scope which, at first didn't even power up.
With help from people on this forum, I was able to fix the PSU and the scope is now turning on.
However, CH2 has an interesting problem, where the signal I feed into it is showing at 50% vertical amplitude from the expected value.
That happens with the channel set in DC coupling mode.
In AC mode, the signal is displayed with the correct amplitude.
Also, in DC coupling mode, the resistance I measure for the CH2 input is infinite, while CH1 is measuring the expected 1 MOhm.
Looks to me I need to remove the CH2 attenuator assembly and check for any issues there.
Would you agree or do you think I should do some other checks first?
Thanks!
Offline m k
Re: Tek 2445 issue with CH2
« Reply #1 on: Today at 12:39:34 pm »
You can also check different termination and attenuation modes.
Since AC is ok upper side of 1st and 2nd switches are ok.
For lower parts you can check calibrator input, 0.2V for DC coupled 50 ohms load.
If removing an attenuator is not a punishment you can also swap them and be sure.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
