Spark gap, in this case basically a glass encapsulated carbon film resistor that has had a groove ground or laser cut all the way around the circumference of the resistive layer, so that it will arc over at a well defined voltage around the 2-300V mark. Only way to test them is with a current limited ( under 1mA) high voltage supply, to see if it does break down and clamp to that high voltage, but they rarely fail unless physically broken or corroded through.
