Author Topic: Trying to figure out what this resistor is  (Read 1046 times)
Offline Bi0Topic starter
« on: August 14, 2024, 04:21:45 am »
Hey all,
I have an Ego battery that is new from this year (already got a replacement want to try fixing this one too).  On the BMS, they changed to using a smd resistor or fuse marked 510 with a line over it.  Package size is 1206.  I opened the replacement battery and that is how I found this, I measured it and it does have a resistance of 51 ohms.  I did find some fuses that have the line above for fast acting and line below for lag time.  But I'm guessing that this isn't the case here since it's a 51 ohm resistor.  Anyone have any idea what that line might be designating?
« Last Edit: August 14, 2024, 05:06:40 am by Bi0 »
Offline gamalot
  • Correct my English
    • Youtube
Re: Trying to figure out what this resistor is
« Reply #1 on: August 14, 2024, 04:53:20 am »
01S = 10 ohm
Sorry I didn't read it carefully.
« Last Edit: August 14, 2024, 04:55:41 am by gamalot »
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
« Reply #2 on: August 14, 2024, 04:54:54 am »
01S = 10 ohm
So I thought this as well.  But if you did it that way the 1 would be upside down.
Offline Wallace Gasiewicz
« Reply #3 on: August 14, 2024, 12:25:23 pm »
Fusible Resistor??
Offline bastl_r
« Reply #4 on: August 14, 2024, 12:31:03 pm »
For a fuse the traces are to small, i think.
« Reply #5 on: August 14, 2024, 03:57:05 pm »
Fusible Resistor??
This is what I was thinking, but I can not find a smd fusible resistor that's 51 ohms.  Was tempted to just use a normal 51 ohm resistor and see what happens...but I'm also not -totally- sure what would happen if it needs to blow if it would cause issues vs a fusible resistor.
« Last Edit: August 14, 2024, 03:58:39 pm by Bi0 »
Offline Smile2016
« Reply #6 on: August 14, 2024, 04:26:02 pm »
51 Ohms , red ink is probably tolerance <1%
« Reply #7 on: August 14, 2024, 05:03:07 pm »
I wasn't sure about the red ink since the blown one was white ink.
I found 2 promising resistors:  1206 package, 51 ohms - one is .5% tolerance and 1w and the other is .1% tolerance and .25w.   I measured the working battery and there's about .19w over that smd.
My main concern was if this is a fusible resistor, would it matter if I just use a resistor that much?
« Reply #8 on: August 19, 2024, 12:05:19 am »
[SOLVED]
A user on reddit was actually able to figure out what this is and figured I would post here should anyone be looking in the future.  TLDR it's NCR's marking system for non-trimming resistors.  The specs are pretty close to the .25w resistor I was already looking at.  Here's a spec sheet for it:
https://www.smart-ele.co.kr/wp-content/uploads/2022/07/ncr_spec_sheet.pdf
Offline ArdWar
  • Country: sc
« Reply #9 on: August 20, 2024, 02:03:10 am »
What is "non-trimming resistors"?
Is it film resistor that are full deposit and aren't cut trimmed? Implying full width current path and maybe higher surge withstand capacity?
Offline TimNJ
« Reply #10 on: August 20, 2024, 02:16:19 am »
I recognized the pink text from TA-I’s catalog (series RAS):
https://www.tai.com.tw/product/5c8yP3CZM4PXDqq7/685ZtD4gg2Qm5uXf
I don’t think text color is at all standardized to mean anything(?) Does the hat over the first number really indicate anything about type?
« Reply #11 on: August 22, 2024, 09:27:32 pm »
I had to look it up too. Basically normal resistors they use a laser to trim them and basically fine tune them to the exact resistance.  These I guess they don't "trim" at all and are just made to a super high tolerance from the start.  From the sounds of it allowing for a higher max working voltage.
