Author Topic: Trying to fix a dead RX 580  (Read 9408 times)
Offline DarximorTopic starter
« on: January 27, 2019, 12:01:08 pm »
Hello all,
I'm new to electronics stuff, I learnt a lot during the last few weeks about repairing dead GPU and motherboard. I own a dead RX 580, I tested some stuff and the two fuse from the 8 pins alimentation seems to not work properly, If I set the multimeter like this, I get the result of the joined image
But an another working fuse of 10A gave me about 00.3 (and a beeping sound)
Do you think that replacing the two fuses with :
https://www.ebay.fr/itm/FUSE-10A-Nano-125v-LF10A-V-Fast-acting-Nano-Littlefuse-0451010-NRL-6-1mmx2-69mm/291509798064?hash=item43df5684b0:g:JK8AAOSwo4pYGxWv:rk:2:pf:0
may fix this problem ?
Do you think that other parts may be damaged beacause of this ?
Sorry for my bad english, I'm french
Thanks !  :)
Offline fzabkar
Re: Trying to fix a dead RX 580
« Reply #1 on: January 27, 2019, 08:01:44 pm »
I suspect that other parts will have been damaged. In any case you should test for short circuits before replacing the fuses. Can you provide the part markings on the ICs?
Offline cdev
« Reply #2 on: January 27, 2019, 08:08:34 pm »
Are you the original owner of the card? If so, what symptoms did it exhibit before it went totally non-functional?
« Last Edit: January 27, 2019, 09:42:27 pm by cdev »
Offline Rasz
    • My random blog.
« Reply #3 on: January 27, 2019, 10:27:55 pm »
similar case to give you an idea how difficult it might be to find the fault
Offline cdev
« Reply #4 on: January 27, 2019, 10:41:08 pm »
See how useful it is to power it with external  power supply set to have a low current limit, and then be able to see exactly what parts are slightly warmer?
No expensive thermal camera needed, I can do exactly the same thing with my cheap LC plastic sheet, I don't need a $500 thermal imager.
It's helped me fix so much broken stuff. Just place the sheet on the PCB and it shows exactly whats gotten warm.
« Last Edit: February 04, 2019, 08:56:34 pm by cdev »
« Reply #5 on: January 30, 2019, 09:45:58 am »
Thanks all for your responses
Yes I must search for a shortcut, but what do you mean n'y ICs ? Is it the BGA chips ?
Yes I was the owner, while gaming the screen goes black, then I have never been able to output things from it (just fans are spinning and logo is on)
Thanks for the vidéo, I found this one also :
https://youtu.be/9iiEbmLcNzg
So I must also search for warm area after trying to power on ?
Do you think that if I short the two fuses and test the cart, I will be able to know if anything else is dead pretty safely ?
« Last Edit: January 30, 2019, 10:56:46 am by Darximor »
Offline cdev
« Reply #6 on: January 30, 2019, 01:59:06 pm »
Do you have a current limiting power supply? Use a value so low not only the fuses can't blow but also no additional damage could be done. And look for very small temp changes.
Offline SilverSolder
« Reply #7 on: January 30, 2019, 04:27:09 pm »
That's an interesting idea.  How do you use the sheet - have you cut some pieces of it to place flat on individual components?
Offline cdev
« Reply #8 on: January 30, 2019, 11:20:53 pm »
Thats exactly what I do, its not conductive, so I just have the PCB horizontal and put them on top of it and immediately you can see the hot spots, if there are any. Its very sensitive.
They are just plastic, the best ones I have are square and approximately 15x15 cm. Thats big enough for most PCBs I need to do it on. You can move it while you're using it, the color changes in real time, almost instantly.
I have accumulated a bunch of them from different sources. The ones I use the most are sensitive between 20-25 degrees C
« Last Edit: January 30, 2019, 11:22:32 pm by cdev »
« Reply #9 on: February 04, 2019, 11:10:57 am »
So I could not find any limiting power supply for sale (except online but it would be difficult). Maybe I can just try starting it and search for hot area on the PCB ? If I understand, that would be where the problem is
Offline cdev
« Reply #10 on: February 04, 2019, 01:29:16 pm »
Limit the current with a non current limited power supply with a big resistor then. You can't apply full power and have this work. It will likely just blow your fuses and remain cold, or do more damage.
Invest in a current limited supply. You really do need it to do this.
Offline Rasz
    • My random blog.
« Reply #11 on: February 04, 2019, 05:14:31 pm »
not understanding something this basic means you wont be able to repair it, just send the card to CORE, they usually charge pretty fair https://www.youtube.com/user/1servicecore/about?disable_polymer=1
Offline JFerris321
« Reply #12 on: February 04, 2019, 07:50:26 pm »
Check the main PSU on your PC, i have seen these fuses blow when the power supply starts to fail in some machines. You can get lucky and it just be the fuses but i would not bypass them, i would relace them if you want to test it.
Offline cdev
« Reply #13 on: February 04, 2019, 08:53:39 pm »
The problem with graphics cards is they take a very high current, so an adjustable voltage and current limited power supply large enough to actually power it at its rated current is likely to be expensive. I don't know much about the specific art of fixing graphics cards, but a few days ago, in another thread about an Nvidia card, there was somebody else asking about a similar problem and one of the people who responsed linked to a video, in Russian showing the use of a thermal imager in the graphics card repair process. So, find that, watch that. Thats what I am talking about, its just the same without the high cost for the thermal imager, but you will still need a power supply. Its likely you can use a much lower current limited PS (even one of the really cheap ones based on a DC-DC converter) to see something very simple like a direct short in some obvious place..  But thats where my knowledge of graphics card repair ends. I take very good care of my graphics card, I do not use it for anything thats super stressful on it, so hopefully it will never blow up like that.
