Hi!
I have this Huawei Smartwatch, model W1 or Classic (have seen both names).
The smartwatch works, but only when it's charging. It charges, but it gets very very hot to the touch.
If I unplug it from the charger, the smartwatch will endlessy reboot until it has no battery left. The battery drains very fast.
Replaced the battery with a brand new one, from Huawei, but I still have the same problem.
Upon disassembling the smartwatch, I identified two missings components on the PCB. This 2 components, are the one's that I circle around on the following image (one on each line):
So, some more help: I tried my best to collect all the info that my knowledge permits, and found out that this 2 components are both on 2 3v lines, one component missing on each line.
This 4 lines (ground, 5.7v, 3v and 3v) are the lines that come from the gold pins, these pins make contact with the charging dock to charge the watch.
So, can this be the root of my problem?
If you guys need any info, I will try to do my best.
Thanks for any help, in advance.
