hello i have been lurking around for awhile and decided to make an account.
i have a tektronix 2245a that when it is turned on hums, clicks, and resets over and over. the first thing i tried was removing components untill the power supply would stay on.
i started with the processor board and with it removed the power supply resets a couple of times and then starts and stays running. at this point i checked the output voltages and the 43v and they are all good. i then removed the power supply from the main board and powered it up and it starts the first time.
i then started suspecting that maybe the caps in the power supply were weak and it was not able to provide the proper volts/amps on start up but i have removed most of the electrolytic caps and they were within spec. i also checked for shorts across all of the diodes and found nothing.
im not sure if im even on the right track here and was looking for some outside opinions/ideas. i do HVACR so i have an understanding of how electricity works and how it acts in simple circuits but this is way out my league. i am a hobbyist so i play around with crt tv's, plasma tv's, basic electronics, and old junk from the 80's-90's but i am no electrical engineer.
anyways any help or advise would be greatly appreciated, thank you.
