Author Topic: Trying to replace a faulty thermal link/resistor  (Read 1407 times)
Offline XaviPachecoTopic starter
  • Country: do
« on: October 01, 2018, 01:02:54 pm »
I found this Thermal Link/Resistor A5MC-220JK to be open. I don't find the same replacement. Is there another way for me to replace it? I thought of a 22 ohms/ 2W resistor, but the actual protection wouldn't make sense then.
Offline coromonadalix
Re: Trying to replace a faulty thermal link/resistor
« Reply #1 on: October 01, 2018, 08:47:09 pm »
you had an response on "all about circuits forums"   why ask here ?  loll
same response  :  https://www.digikey.com/products/en?keywords=285-1901-ND
Since it has an 18week of lead time,  put an 22 ohms 2w resitor in serial with an 139 degree thermal fuse, thermally glued or an shrink against the resistor.
« Last Edit: October 01, 2018, 08:52:39 pm by coromonadalix »
  • Country: do
« Reply #2 on: October 01, 2018, 09:30:19 pm »
Well.. I just wanted to hear a different approach from someone else  :-\
I needed a fast solution rather than waiting long only for that component. I just thought of putting the 22 ohms resistor without the thermal fuse. Of course, I know the consequences if it fails again  :D
A faulty bridge rectifier caused the thermal link goes away. I've replaced the bridge, I'm only stuck for that component, and I just have the 22ohms/2W resistor at the moment.
« Last Edit: October 01, 2018, 09:34:43 pm by XaviPacheco »
Offline macboy
« Reply #3 on: October 03, 2018, 01:05:11 pm »
Hmm, for me it shows:
"Quantity Available   25,869 Can ship immediately "
In this case, the manufacturer lead time is of no consequence, unless you need 25870 of them!
edit: Apparently Arrow has free shipping worldwide on all orders no matter how small. But be prepared to receive a very large package for your one component.
« Last Edit: October 03, 2018, 01:07:40 pm by macboy »
