Its hard to be 100 % confident without further information about the schematic and connections, but it seems to be a current sink (drawn strangely):
R2 & R?150k may be an R divider to feed Q1 collector voltage back to the CPU.
R?4k7 is probably the 'turn-on' signal -- it also provides base drive to Q1.
See Q1's emitter goes to GND via a 10 Ω R1. This voltage is monitored by Q2 (basically compared to the 0.7 VBE needed t turn it on). If the voltage tends to exceed 0.7 V, Q2 will turn on and shunt base current away from Q1, thus tending to turn it off.
In the end, it all acts as a current sink at a level of about 0.7/10 = 70 mA. Depending on beta of Q1 and the voltage applied by the CPU to the 4k7, there may not actually be sufficient base current available. Note the base of Q1 is at about 2*0.7 = 1.4 V. So, if CPU is at 3.3 V, you get a base current of (3.3-1.4)/4.7k = 400 uA; you'd need a guaranteed beta of 70mA/0.4mA = 175 to make this work. This is ignoring the driver resistance from the CPU (maybe 1k ?).
I would suggest changing the 4.7k to ~ 1k to ensure it actually regulates as intended.
It's hard to see how Q2 could have been damaged; its collector current is limited to << 1 mA by 4k7; it is possible the circuit oscillates, or Q1 became damaged and passed the input voltage through, but that is probably unlikely.
