Author Topic: Trimble Thunderbolt GPSDO  (Read 1698 times)
Offline TheSteveTopic starter
  • Living the Dream
« on: June 12, 2016, 03:51:25 am »
A friend of mine dropped off a Trimble Thunderbolt GPSDO that stopped working. The OCXO still heats heats up, all voltages/supplies look good. I can see activity on the data and address lines of the firmware memory(29F400) however the data sure looks ugly. You can see edges galore on every single data line, they aren't from a probe grounding issue.
I have attached a pic, the yellow trace is an address line, the blue is a data line. I really can't imagine something working with such noise on the data lines.
Thoughts?
VE7FM
Offline edpalmer42
Re: Trimble Thunderbolt GPSDO
« Reply #1 on: June 12, 2016, 06:06:34 am »
What do you mean by "stopped working"?  Stopped talking, off frequency on one or both outputs, all of the above?
Ed
  • Living the Dream
« Reply #2 on: June 12, 2016, 06:17:54 am »
Ed
All of the above. There is no serial communication and the OCXO is not controlled.
VE7FM
