Author Topic: TTI / Thurbly Thandar TSX3510 Repair  (Read 3832 times)
Offline TheBayTopic starter
  • Country: wales
« on: January 22, 2014, 10:28:43 am »
I have had this power supply for some time and has served me really well. It is a Mixed mode design based on SMPS but precision.
It's just the Standard non programmable TSX3510 35v 10amp, the version that has a dark grey case, not the recent white one.
Recently I was trying to charge some SLA batteries and forgot I had one trickle charging, ever since then this PSU has been playing up.
The fault is, if anything draws over 800ma+ the Constant Voltage light flickers on and off (Does not go to constant current, which is correct), and the LED segment display shows a brief drop in Voltage, If I have a multimeter attached it constantly shows the voltage the the display drops to, not what is displayed on the PSU
Constant Voltage/Constant current switch over is working correctly.
If I connect a dummy load at say 500ma it all works correctly and the multimeter reads correctly.
Also when it is not working correctly it makes an awful buzzing/whine from one of the SMPS transformers, this PSU was near silent previously.
I think an SLA has backfed or shorted out causing damage. I do have the schematics for this PSU, any help will be gratefully appreciated.
I love this PSU and would love to get it back in action.
« Last Edit: January 22, 2014, 02:51:56 pm by TheBay »
Offline macboy
Re: TTI / Thurbly Thandar TSX3510 Repair
« Reply #1 on: January 22, 2014, 03:56:00 pm »
Do you have the full service manual or just schematics? I can share the service manual with you if needed.
  • Country: wales
« Reply #2 on: January 22, 2014, 05:59:41 pm »
I've been sent a service manual from TTi.
I guess that's the same as what you have?
Offline djsb
« Reply #3 on: December 24, 2022, 09:43:50 pm »
Did you ever get this fixed? Just curious. Thanks.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
  • Country: wales
« Reply #4 on: December 24, 2022, 10:21:02 pm »
It was the large capacitors in the primary side.
