Yeah.. I can't really understand your reasoning there but if the speed and depth are turned fully down and the tremolo turned off at the foot-switch and the hum totally goes, it's likely going to be the tremolo circuit that is the problem.
To troubleshoot V3, it looks the same tube as V1 or V2, you can normally plug in the guitar via a foot pedal straight into the effects loop return (only). You may also need switch the bypass off (read the manual if you are unsure where any of this is).
The idea is to isolate the front end of the amp from the recovery/power amp end via that effects loop. Then if you still have the problem you could swap V1-V3 and see if replacing V3 resolves it.
If all this sounds confusing and you have never replaced tubes before etc then you should take it in for warranty/servicing.
Thank you for the reply good sir.
The state is:
Humming is always on and doesnt care about the volume knob (the humming is at the same volume even when I turn the volume up). So so my reasoning it cant be the first two valves V1 and V2, cause you cant hear them when volumes is turned down. I doens matter if I disconnect evrything, bypass the loop
(of course the amp also has the normal tube amp noise when volume turned up, but that is ignored here because that is the normal function, and I also forgot to mention, the amp works well and sound good except this added hum)
The humming is effected by the tremolo, so the humming must be infront of the tremolo. The powertubes are after the tremolo so the hum cant start in those tubes.
I have no problem with changing the tubes, I dont have any spares and would, but a rotate of V1, V2 and V3 is a smart option if we know that it can be one of these tubes that makes this hum.
I tried the thing with the pedal, I dont have a pedal but I made substitute with a stereo tele plug and two switches. The humming is still on even when I turned the tremolo off with the foot switch jack.
I will take it to the shop if we can show that all the tubes are fine, tubes are replacement part that is not covered by warranty.
And dont worry, Im smart enough to not take any chances, I know that the filtercaps can contain at most 400V even when it is turned off and unplugged.
