You can get a 4 or 6 way power board with a single/master 2 pole switch for cheap,
if you don't want to go the separate socket and switches style board
Even a single pole switch is better than sparks and arcing you don't need
I doubt those overpriced overhyped 'Surge Protected' boards will do much for your gear if they cop a real hit
and using an RCD TEST button for turn off may trip the RCD at the main switchboard too occasionally/randomly. How do I know this?
But yeah, source a Tek switch (or two!) as well, and have a go at fitting it when you're ready,
or next time opening the scope for other reasons or give it some TLC
fwiw even if you don't fix it and sell the Tek later, the buyer will go for it with less hesitation if a switch is supplied
