Needing some help with this Onkyo CP-1010a.
This turntable spins at a constant 90-100rpm, with no speed controls. The speed selector switch does not switch between speeds (be it faster or slower than 100rpm lol,) the pots don't have any effect on the speed, nor do the internal trim pots.
I have sprayed the pots, speed selector switch and onboard VRs with deoxit
I have checked for continuity between the switch open and closed, between the switch open and closed to the pots, and the speed control board. There do not seem to be any shorts. I have also checked for continuity between the speed board and the motor via the white and yellow wires and there is continuity there as well.
I have checked for resistances at the 33/45 potentiometers and 33/45 VRs and all line up with the 1010a manual. I also checked that the 6.2k and 22k resistor were in spec.
I replaced the 1000uf capacitor, as well..
The motor seems to just spin at full power with no adjustments. Initially, I thought there was a short but now I'm not so sure.
Could this be the x2 film cap between the switch or a bad transformer?
Any help and insight would be greatly appreciated.
