link=topic=256782.msg3273254#msg3273254 date=1602457659]
The only time I have seen a crystal oscillate at a frequency which was not a harmonic was in an IBM PS/2 Model 25. In my case I suspect that there may have been a dag on the crystal when it was trimmed, and this dag subsequently fell off during normal usage. Can you hear any rattling when you shake the crystal?
You might also want to check the LC passives.
[/quote]
No rattle when shaking the crystal. I don't have a cap tester that goes as low as 15p, but I ordered some replacement caps anyway. I am not sure how to match up that candy style inductor, but I ordered a wires wound one along with all other passives based on best guess.
Are you just relying upon the frequency readout of the 'scope, or have you measured the duration of a cycle in the time domain?
It should be about 279ns for 3.58MHz, & 106ns for 9.4MHz.
I first came up with approx 100ns on an old analog scope. I then put the PicoScope on it and it shows 9.4MHz. I believe it is accurate, but I plan to check on my Tek465 (highest Mhz sope I have) when I tackle the project again next weekend. I could be off on my counting.
I think the colourburst osc might be ok, it's just getting loaded down by the scope input capacitance?
Do you see chroma signal (colour burst) at the Jungle IC input pin 46 from the composite video? Just to make sure you have a colour signal coming in. It gets filtered out for luminance signal split to pin 43. You can compare the signals at those two pins to see what's going into the jungle IC. The IC is also in KV-2137RS, KV-2127RS
Look at the Saturation control voltage at pin 39 3.5VDC that it's not 0V.
I suspect the scope input capacitance is loading it down, but I have no way to validate that. There is a comb filter that is buffered with a half dozen transistors before the luma and chroma. I pulled out the transistors and tested them all and they are good. I am getting a chroma and luma signal to the jungle chip. Thanks for the information on the other TVs that use this chip. I have a watch on ebay for the PCBs. I checked all the pots for color adjustment and they appear to be working fine.
I assume you did verify that you are getting color video out of the laserdisc player? Many players have Svideo outputs too which will be separate chroma/luma signals, ie B&W video and a separate color signal. With old arcade games it's pretty typical to find all kinds of random hacking from past techs.
Yep. Player works great. The monitor has color when I feed it an RGB test signal.
