This is what the LEDs from a Warehouse branded Veon TV look like after two years of home use - I have to laugh at their "Green, Sustainable, and saving the planet" angle they're using to push this kind of product into landfills here - referring to their current television commercial.
Repair is even more difficult than a brand name TV as the white reflector material is glued in and not removable, making changing the strips impossible without cutting the reflector or tearing it out and stitching it back together with clear tape.
Imagine what a TV LCD panel would look like when backlit by a UVA germicidal tube if you want an idea of the symptom. No reds and greens, and an abundance of blue.
