hey rasz,
You might be right: when I googled FSFR1700 it brought this datasheet (
https://www.fairchildsemi.com/datasheets/FS/FSFR2100U.pdf) and I saw in page 3 the following pin description:
Pin 2: CON - This pin is for enable/disable and protection. When the voltage of this pin is above 0.6V, the IC operation is enabled. When the voltage of this pin drops below 0.4V, gate drive signals for both MOSFETs are disabled. When the voltage of this pin increases above 5V, protection is triggered.
Well, due to your comment I decided do check again and found this other datasheet (
https://www.fairchildsemi.com/datasheets/FS/FSFR1700.pdf); both are VERY similar and mention part FSFR1700 - but this one does not mention pin 2 being an "enable / disable" pin indeed!
The pin labels in the schematic seem to match the first datasheet though... so I'm not sure at this point.
Anyways, that seems to be a red herring. I checked the supply to the LVCC pin 7 as you suggested and indeed, nothing there. The control portion of the circuit is not being powered up (I measured it between pins 7 [LVCC] and 5 [control circuit ground).
What powers this LVCC pin is a rail called VCC1, which in turn is generated via the TL431 based circuit you also mentioned - I probed there and
niente... I continued to trace it going backwards and found this VCCP bus that powers the TL431 circuit not to be working!
This VCCP rail being generated by a little circuit in the first page of the schematic, left-bottom corner. It's just a transistor and a couple resistors; well, there is no voltage coming out of that QB901 PNP transistor! That's where this VCCP bus should be coming out of. I checked the VCC rail that powers this transistor and there I do get a voltage (17.7 V); so it must be this transistor that is faulty!
mij59: as you can see above, I checked LVCC as per yours and rasz suggestion and you guys are right, there is nothing there... that's a problem!
Does my analysis make sense?
Thank you all for the help so far!!!
