Author Topic: TV Power Supply Repair (Vestel 17IPS20)  (Read 1458 times)
Offline smilgyTopic starter
  • Country: ie
« on: August 18, 2022, 08:31:53 pm »
I was wondering if you perhaps could help me troubleshoot a TV power supply that has failed.
In my process of troubleshooting, I have found the main fuse, bridge rectifier diodes (D112, D113, D114 and D115 on the attached schematic), as well as D101, D512 and D513 in S/C. I replaced the fuse, and the mentioned diodes, however all of the above failed again, as there is probably still another short somewhere? However, I am unable to find it (relatively inexperienced in this subject). Any thoughts what I should be checking next?
Thanks,
Online inse
Re: TV Power Supply Repair (Vestel 17IPS20)
« Reply #1 on: August 18, 2022, 09:21:18 pm »
This is the nastiest schematic I've seen for as long as I can remember.
It is not a document to support repair, it's an obstacle!
A dead Q301 might kill D512/513.
Only D101 broken, but not 102 and 506 (who made those references???)
Are D104 and the bridge rectifier diodes (D112, D113, D114 and D115) in parallel, or am I too stupid to read this schematic?
« Last Edit: August 18, 2022, 09:36:53 pm by inse »
The following users thanked this post: smilgy
  • Country: ie
« Reply #2 on: August 18, 2022, 10:18:11 pm »
It took a bit of effort to remove q301, but I did. Would I be right in saying that it is dead judging by the tester?
Online wasedadoc
« Reply #3 on: August 18, 2022, 11:03:34 pm »
Yes.
  • Country: ie
« Reply #4 on: August 19, 2022, 08:27:02 am »
Replaced the mosfet with a close similar, and TV powers on! Time to get the correct replacement.
Online inse
« Reply #5 on: August 19, 2022, 08:32:34 am »
Double thumbs up  :)
Offline FIXITNOW2003
« Reply #6 on: August 19, 2022, 12:01:41 pm »
Training book for psu if anyone else drops on to this page ,it may help
  • Country: ie
« Reply #7 on: August 19, 2022, 03:22:57 pm »
Thanks, I'm sure this will help someone. I had initially thought Q301 had failed, but was not 100% sure with the component in circuit. I had forgotten I had the component tester as pictured, and once removed and tested, it seemed obvious, especially the S/C path taken.
I'm by no means an expert at repair, so was fun to fix this, even if with the help of others!
