Author Topic: tv power supply  (Read 839 times)
Offline glinjikTopic starter
tv power supply
« on: August 19, 2021, 05:38:37 am »
Hi I'm having trouble getting this power supply to work going left side ac input the two caps are good x2 cap good bridge good elec cap good thermistor good  that filter next to the bridge is burned so I just bypassed it. it's there for the photo only but that ruddy fet  keeps popping diodes are good it's like the is a short somewhere could the big transformer be burned?  |O
All the truth in the world adds up to one big lie (Bob Dylan)
Offline shakalnokturn
Re: tv power supply
« Reply #1 on: August 19, 2021, 09:43:09 am »
SMPS transformers can fail (more often small ones and they'll fail open) but it is quite rare.
The most common is that the FET will short due to bad capacitors, overload if there is no OCP, bad solders, dead opto or TL431....
Anyway the odds are that once the FET has blown it has also destroyed the PWM IC which will also need replacing to not blow replacement FET.
First of all try to identify the initial cause of failure.
Offline aqibi2000
Re: tv power supply
« Reply #2 on: August 19, 2021, 06:29:42 pm »
Build a ring tester or use a curve tracer
Tinkerer’
The following users thanked this post: glinjik
Re: tv power supply
« Reply #3 on: August 19, 2021, 07:33:34 pm »
so having a look a lot closer i found the pwm controller (FAN7602) pic below with suspect gunge below it the other pic is the filter completely burned no idea what could cause the filter to burn up
